White's '95 GT "Unicorn"
white95
white95
Apex Junky
Admin
Prairieville, LA
its something ignition related. Your rpm says "syncing" the entire time. It should read that for a half a second before you see the rpms register in the tach.
That is what I'm thinking. It was switching between sync/stall but i swapped polarity on the crank sensor to see if it helped. This was before I swapped it:
it looked like it was trying there but I am not sure what to recommend. Do you have it set up for digital rising or falling in the settings? The way it looked like it was hitting every so often makes me wonder if it isn't in your settings. There is a facebook holley efi group that is pretty good at answering questions. Have you started to regret the choice to go stand alone yet? It comes and goes.
white95
white95
Apex Junky
Admin
Prairieville, LA
it looked like it was trying there but I am not sure what to recommend. Do you have it set up for digital rising or falling in the settings? There is a facebook holley efi group that is pretty good at answering questions. Have you started to regret the choice to go stand alone yet? It comes and goes.
It may be setting related. I'm in the mod motor with Holley EFI group.
Regret? Not one bit.
I have a remote tuning session with Scott Clark Friday. It’ll either be running or I will know why it’s not running.
white95
white95
Apex Junky
Admin
Prairieville, LA
What ended up being the issue?
It needed Scott Clark’s touch. The crank sensor wiring needed to be reversed. We have it running waste spark for now with the cam sensor unplugged. Once it registered RPMs, it fired right up and it needed to be tuned. The fun stopped when it sprang a water leak. Looks to be the rear coolant crossover. Hoping it’s not too involved to remedy.
white95
white95
Apex Junky
Admin
Prairieville, LA
This cloud of god knows what made me extremely happy.
My AN power steering system is leaking at the hydro booster.
This hose has to be reworked.
This will require some minor disassembly to locate and hopefully it’s not a very involved repair.
Someone is jealous of the attention.
Burninriverdiver
Hell yeah it’s alive! Nice work, now you just have to keep plugging away at the little things that pop up. Hope to see it on the road soon
virocanah
