your neighbors only thought they hated you till you pull out the media blasting stuff.
Full patina...
Sent from my SM-G955U using Tapatalk
They call them ratrods hahahaFancy term for shitbox
Dude, nice save! Could've been even worse.Instead of sulking and having a bad evening I just dug into it. At first, I didn’t see the issue because I was looking for signs of obvious wear.
Quickly found these loose cam phaser bolts and fixed it. Had to step out for a stupid shallow, 12 pt, 10mm socket so this repair cost me $4.75.
I think the next turn would’ve spelled disaster. Talk about a close shave with tragedy.
Did jacking up the front of the car work on helping remedy the air bubble?
Did you maintain the heater core?
I thought about connecting the dash to the signals and high beams but once I got the dash set up that I liked there was just not much space for much else. I also thought that the brake system would have a fault if there was no parking break light but I might be wrong there.
hey man not sure if this helps but check out this website for silicone parts and pieces.
http://www.siliconeintakes.com/
Revised list of tasks needing completion in order to drive the car around the block:
- Wire PWM to fan controller
- Finalize throttle cable
- Cold air intake
- Firewall adjuster/adjust clutch
- Belts/hoses/tensioners + bolt
- Coolant
- Install MM steering shaft
- Change rear end fluid
- Square K
- Front brakes
- Brake fluid + bleed
- Wheels/tires
