Drove the car to work yesterday and the fan was still working fine. When I got home, fired the car up to do some data logging and the fan then abruptly stopped.
Great. Set the PWN to 20% @ 0 RPM and started to troubleshoot the issue. When I wiggled the fan connector it started to run. Pulled it off and found this:
Dammit!! Looked around and found the original fan from my cars pushrod days and put it back in. It fits the 5.0 style radiator so much better than the 4.6 fan did, imagine that. I’m going to replace the fan connector as soon as it arrives in the mail. The entire setup will be revamped with either the Delta PAG setup or something comperable that’s readily available.
Devon sent me a progress picture of my heat extractor hood. I’m stoked.
Also added some PS fluid to the reservoir and now the pump doesn’t bitch nearly as much. I’ve been meaning to bleed it again but it seems the air reached the surface on its own as indicative of the low fluid level.
