Who are the 4.6L 2V experts?
delling3
Sterling Heights, MI
I have a stock NPI Motor. I have a new FRPP Intake and a set of PI cams sitting here awaiting install. Not sure if I want to tackle both at the same time, or do the intake first, and hold off on the cams for a bit.
Is there any benefit to doing both at the same time? Is it significantly easier to change out the cams with the intake off the car? This will be my first time working on the Mustang. Sure looks cramped in that engine bay . . .
lwarrior1016
Mr. Secondary Timing Chain
South Mississippi
When the intake is off, there will be a lot of things already out of the way. I’d say do them at the same time, but make sure to put tape over the ports so nothing falls in. Are you going to pull the timing cover or try to do it without taking the timing cover off?
RAU03MACH
NEW MEXICO
I would say do both at the same time
Makes no sense to do half one week
Tare it down again to do the other half
That would be doing double the work
That's just me
Worroir 1016 right on the money
delling3
delling3
I have been warned enough about the pitfalls of trying to do the cam swap without removing the timing cover, that I have been "scared straight". So the timing cover is coming off, new chains, guides, and a new water pump are all planned as part of the deal. If I had done this before, and new what I was doing I would probably try and pull it off without pulling the cover.
Part of my concern is my lack of experience. I am confident I can get it done, but what might be a weekend job for some of you guys will probably get dragged out by me due to a large dose of over-caution. I really don't want the car sitting for weeks on end. If I had a heated workspace, I could do it in the winter, but no such luck.
RAU03MACH
NEW MEXICO
Ya that's another thing you want a clean dry place to work in ,keep all dirt and dust out of the engine , and some of that stuff will take time to work especially if you dont have the proper tools
Just take your time take pictures in case you loose track always find top dead center look for the Mark's on the chains
It is pretty easy
Wrenching can be fun knowing you did it and not someone else
I think you can do it
lwarrior1016
South Mississippi
Honestly man, pulling the cover and intake and cams, that’s like a 3-4 hour job. I’m confident you can do it in a weekend if you have the right tools.
delling3
delling3
I have a fair amount of wrenching experience - DOHC motorcycle engines, pushrod 4-cylinder car engine, etc. Have no hands on experience with V-8's of any type. I think I have a decent collection of tools. My challenges are the work-space (cramped, unheated garage with crap lighting), and lack of familiarity with the Modular V-8. I am confident that I can do the work (good, since I can't afford to pay for it), but I know I will be taking my time to get it right.
white95
Apex Junky
Admin
Prairieville, LA
If you don’t pull the timing cover you won’t be able to inspect the crank gears which are prone to wearing out over time.
96blak54
In the shop
You gonna need a dampener puller, rtv, razor blade, basic tools. Youll be fine. You got us to ask questions.
Keep in mind that a pi intake on npi heads is a 2 day process. The blob of rtv needed in the water port needs a good day to dry up.
Connie
Acworth, GA
What I can say is, if you've never done something that seems intimidating to you, do like I do and find some YouTube Videos that are in line with a big job your planning. Watch them a few times to get comfortable, and familiar with the process. I haven't had to go into our Engines like your planning, but it has helped me with difficult jobs I had to do, that I've never done before. BOB.DSC00053.JPG
delling3
delling3
I agree the mechanically speaking, your’re “almost there”, but then there is the expense. If I were going to change the heads, you have the cost of the heads, head bolts, and gaskets. I wouldn’t install used heads without doing a valve job, so add a significant amount of machine shop $$. I know I am losing about 10 hp as compared to PI heads, but the cost is significant.
white95
Apex Junky
Admin
Prairieville, LA
The difference between a partial PI swap (PI intake/cams + NPI head setup) vs a complete PI swap is greater than 10 hp! If you can, do it. If you don’t, you will beat yourself up and then just do it later.
Silver95bird
Dyno proof, please.
Sent from my moto z3 using Tapatalk
TreeScholar
Staff online
