why do I have two rear sway bars??
Rescuefighter
Pensacola FL
Just acquired a 1998 svt cobra super charged by steeda . was noticing a floaty feeling at 60 and worsens to almost uncontrollable floating to the right to the point of getting sideways . after getting back home took a look underneath and see two separate sway bars? the upper bar is within a 1/16 from touching the diff on the left side and isnt centered . looks alittle bent as well . what is its purpose can it be removed . I was looking at replacing the standard sway bar for the 1" steeda version but then discovered this car has two bars on the rear . any thoughts ?
shovel
Edit: I stand corrected that is apparently a historical Steeda product -
I did NOT expect it was intended to be used in combination with the stock bar, that's awful and I hate everything about it. I had assumed it only existed for use with tubular arms on a coilover rear suspension that don't have the "flags" for the stock bar. Interesting that in the photo I was able to find it seems to have springs built into the end links, as perhaps a way to tune the bar. Did I mention I hate everything about it?
That said, there's no way that bar has anything to do with the floaty feeling you described.
These cars do generate some lift, both from the negative pressure in the wake of the rear window & top of the trunk and from air getting under the car. The stock air dam thing under the radiator support helps quite a lot with that but it gets scraped off on parking blocks and other road hazards especially with cars that have been lowered. It's cheap and easy to put a new air dam on, or a full front lip if you prefer the look.
You'll probably also want to inspect all of the bushings in your control arms, and make sure your steering alignment is in spec. A little toe out can lead to kind of a floaty feeling in the steering wheel at speed. It looks pretty likely that your rear upper bushings are vintage so they're going to need to be pressed out and replaced at minimum. There is absolutely no need to go with hockey pucks up there, fresh OEM style rubber is more than enough. These cars are not dangerously unstable stock.
I strongly doubt there's any good reason to keep both rear sway bars on the car. The weird 2nd one might be just what somebody is looking for to complete a build they've got with tubular arms, so maybe you can make a buck selling it. One thing that I'd advise you to put some more research into is proper balance on sway bars - stiffer isn't always better. They can be a band-aid for a lengthened roll couple on a car that's been lowered without roll center correction, and they can be a way to make the car feel more communicative on track or to balance front/rear weight transfer on cornering but that's not as simple as just make it stiffer. Cobras left the factory with smaller front sway bars than GT's on purpose, and as a general rule softer sway bars (with correct roll center geometry) will be more progressive and controllable at the limit than cars with too much sway bar.
R
Rescuefighter
Pensacola FL
yes all the bushings are in pretty rough shape it looks like, as well as the shocks . i was contemplating changing the control arms out to the steeda weight jacker adjustable ones ? That was my thought on fixing the floaty issue until i saw the sway bar setup . But just want to get it running good first before i start changing things out. I will def either change all the bushings or go ahead and buy/install the adjustable control arms and new shocks all around . they are extremely rusty the fronts have rust holes.
the unstable feeling was just a little surprising last weekend when driving it for the first time . the rear end was all over the place and if hitting rough spots in road it would get worse .
Ive spent the last month just getting it to crank and run . lots of little parts and hoses and fluid draining but Finally got it running at least enough to test drive it so I will start on getting parts for the suspension while i work on the engine issues . I inherited this car from my father in law who passed recently . I didnt even know he had this car. it has sat in a field for the last 12 years, and it only has 32k miles on it . so far its just been alot of small parts replacements and alot of cleaning and draining /replacement of fluids, and replace or rebuild of brake calipers and lines , and now on to the suspension.
Thanks for the good advice and input, Im glad to see another picture of the dual sway bar . I thought I had a unicorn ??
I have another weird to me part i have discovered but i will post it up later once I get this suspension issues fixed
dsrtjeeper
After the new bushings and shocks/struts; you'll want to have an alignment done. The thrust angle could be off if the rear diff isn't centered.
R
Rescuefighter
Pensacola FL
I think the diff angle is off anyways now? The car is 2 " lowered and the upper control arm is not adjustable . being not adjustable and lowered Ive read that will cause it to be out of alignment . This will deffinitely be on the tasks to check out to get that angle correct . Im taking lots of notes to remember all the to do's
Thanks
dsrtjeeper
Thanks
The pinion angle is definitely off.
Warhorse Racing
It's hard to tell from the photo, but it looks like you might not have the springs on the end links that Steeda included with their adjustable rear sway bar. The springs are really important to the design.
The Steeda adjustable rear sway bar was, in my opinion, one of the best bang-for-the-buck mods ever made for 79-04 Mustangs. It's designed to work in addition to the rear sway bar mounted in the factory location. The end links are adjustable. The more you tighten them, the more oversteer you add to the car (reducing understeer). More threads = more oversteer. Adding too much oversteer makes the car more likely to lose grip in the rear. I used this sway bar on two of my autocross cars for years. When adjusted correctly (along with my other suspension settings), it helped my cars handle as well as/better than other Mustangs with more suspension mods. The problem was that most people didn't know how to adjust it correctly and they ended up making their cars handle much worse. People also didn't think a $150 sway bar would work as well as more expensive mods. So, unfortunately, this awesome part was discontinued.
If you want to know more about adjusting the Steeda sway bar, I'd be happy to answer any questions you might have. If you don't plan to use it, please don't throw it away.
Warhorse Racing
Very interesting! What are your thoughts on their 5 link rear suspension?
I've never personally used their 5-link. Full transparency, I'm far from an expert on the 5-link, but my understanding of it is that people didn't know how to adjust it properly, so it didn't catch on as well as other upgrades from other companies. In 13 years of autocrossing my Mustangs, I've never seen a car using the Steeda 5-link. A fellow autocrosser found one recently and is planning on using it in the future. I'm excited to see how it does. I can say that, based on how my cars performed with the $150 Steeda adjustable rear sway bar (and other mods) at my local events, I didn't feel the need to purchase the 5-link. I always try to do more with less when it comes to suspension. But I have been very impressed with the Steeda parts I've used (I've reviewed a bunch of them on my YT channel).
R
Rescuefighter
Pensacola FL
Thanks for the info . I would like to keep it if it serves a purpose and is an upgrade to the handling . My current problem with it is that it appears to be off set /not centered as the left side of the sway bar is actually touching the diff cover . It does have the springs on it Ive attached a pic of it. The entire rear end is floaty at the moment. at 60 mph it drifts to the right to the point it feels like its going to slide out while just casually driving down the road, any bumps amplifies the issue.. I have decided to just replace the upper and lower control arms with adjustable ones and replace the rear shocks . Since all the bushings need replaced I might as well upgrade them to more functional if the originals have to come out anyways. Im not sure if the factory location sway bar is upgraded or original? but it needs new bushings as well as the steeda extra sway bar . they are pretty dry rotted and cracked . as I mentioned in previous posts this car has sat in a field for the last 10-12 years so it needs alot of rubber parts replaced .
I had to do some trimming on my diff cover to fit it. It was a cast aluminum unlike the stamped steel stock version so there was room to trim.
Warhorse Racing
I'm always happy to help. There's a lot to unpack here, so I apologize for the long reply...
Replacing all of the rubber bushings on a car that old that has been sitting for that long is the exact right plan. It's an involved process, but bushings are (in my opinion) the secret sauce to getting these cars to handle much better than stock. There are lots of options out there. Some are much better than others when it comes to handling. If you let me know your goals for the car, I'd be happy to suggest bushing options. Because it might be tough to find replacement bushings for the Steeda sway bar, and because your other bushings could potentially be part of the reason why the Steeda sway bar isn't centered, I suggest replacing the other suspension bushings first. Don't forget about steering rack bushings.
You can measure your sway bars with a digital caliper, an open-end wrench, or an adjustable wrench to determine if they are the stock sizes. A 1998 Cobra came with 29mm F & 27mm R sway bars. If I'm not mistaken, Ford also put some 25mm rear sway bars on some Cobras because there were issues with the 27mm rear bars (you should double check that).
If you end up not being able to use the Steeda sway bar because you can't find replacement bushings, you can choose other sway bars that work with the rest of your mods. Sway bars are used to fine-tune the suspension. You need to know what sway bars you have and what tendency (understeer or oversteer) you are trying to dial out of the car with the sway bars. Don't just put two stiffer sway bars on the car; that might not be what it actually needs.
You mentioned that the car is lowered 2". Lowering springs that drop the car that low aren't ideal for handling. When it comes to lowering springs, I don't recommend lowering an SN95 Mustang more the 1.25". My autocross cars don't look cool, but they handle extremely well. Suspension has to articulate. Going too low limits suspension travel. When you run out of suspension travel, bad things can happen. If you want this car to handle better, I strongly recommend different lowering springs. I'd be happy to suggest springs based on your goals for the car.
Deciding on springs will help you decide on shocks & struts. They have to work together. And you have to think of suspension as a system, not just front and rear.
These videos will give you more information:
R
Rescuefighter
Pensacola FL
Thanks for all the help and getting me in the right direction. Ive contacted Steeda trying to get info on the second sway bar for the bushings as well as given them the VIN trying to figure out what all they did to this car back in 1998. Its a steeda built car with vortech super charger steeda tune, and looks to have alot of steeda suspension upgrades. the lowered springs are steeda the shocks and struts and quads are unknown brand they are rusted up and cant read the info on them. but everything looks to have had a performance upgrade to it. . I guess my main goal is to get this car back to a reliable operational and performance level. I will play around with it some for fun but mainly a weekend cruiser and may go meet up with the young guys and play alittle :) every once in a while and enjoy the car . So i dont mind spending the money to get it upxated with newer performance parts to get it running and handling better . Like I mentioned , This was a car my father in law had built by steeda straight off the show room floor , that he left to me , and that I didnt even know he still had. He would always talk about this car in past tense LOL , Last time I saw this car was in 2006 . I thought he had sold it. But ater digging around asking family this car sat in a barn from 2006 till 2016 then moved to a field due to barn damage where it has sat ever since . I have found that since its my wife's dad old car she doesn't mind me throwing money at it :) so far its allowed me to get a lift added into my garage to work on it so now I have a new project .
Warhorse Racing
It's definitely a car that's worth trying to save. And, if the control arms are from Steeda, they offer replacement bushing kits for them. You can certainly achieve your goals by using Steeda parts if you want to keep it close to how it was originally modified. You won't be disappointed by the quality or performance of Steeda parts. I think many of us would love to hear what Steeda has to say about the history of the car.
shovel
I think a lot of performance upgrades on those upfitter cars were more about trying to throw as many random items on the car as possible so they could make money on the upfitting.
I want to clarify in this next bit that I work as an engineer but not a mechanical engineer so I think it's fair to say informed but not authoritative. Having said that, I can't help notice that nothing OEM comes with double sway bars. There might be some advantage to having a singular sway bar mounted onto the axle independent of the control arms so that the sway bar itself is decoupled from the same bushings which control axle wrap and the four-link arrangement that also handles lateral motion - but if there was much substance to that Ford could have done it themselves when they made the Cobras.
Instead the SRA Cobras tended to get a slightly larger rear bar, slightly smaller front bar to reduce understeer. Most cars are made to understeer because collision safety hardware is focused on forward collisions so it's more survivable to hit something with the front bumper than the side. Cobras had grippier tires and perhaps a more demanding customer so they tuned out some of the understeer. Going too far with that to promote oversteer might look cool in the hands of Keiichi but for real roads and regular drivers it just means we'll be able to buy parts off your car on ebay when the dismantler parts it out.
Maybe I've just seen the same story play out too many times.
Lucky57
