Warhorse Racing
- Joined
- Apr 3, 2019
- Messages
- 327
- Reaction score
- 330
The Steeda adjustable rear sway bar allows you to dial in the handling tendency you prefer: understeer, oversteer, or neutral. On the street, most people will never (and should never) push their car to the limit of traction. On an autocross course, your car's tendency at the limit is extremely important. Your ability to adjust the car in between runs is important, too. And, because some classes allow very few mods, getting as much adjustability in the car as possible with those limited mods is key. I always tell novices that adjustments matter as much as mods. If I needed to, I could adjust the Steeda rear sway bar in between autocross runs. I wouldn't have time to change out a rear sway bar in the factory location.
Many common mods impact the car's tendency to understeer or oversteer. Having a part that allows you to compensate for those mods gives you more power to control the personality of the car. Combining the Steeda adjustable rear sway bar with adjustable shocks & struts, the right caster/camber settings, and air pressure settings helped my cars stay competitive against cars with more mods.
There is a definitely a downside to this: If you crank the adjustable rear sway bar all the way down (adding the most oversteer), the car will be extremely tail-happy.
Detroit Speed offers a similar adjustable rear sway bar (with limited adjustments).
If people can't find a Steeda adjustable rear sway bar and don't want to spend a lot of money on the available adjustable rear sway bars, installing a stiffer rear sway bar in the factory location will help reduce the "factory-installed" tendency to understeer.
