My '96 GT VIN says "X" in slot number 8, so it must be a Windsor? But the valve covers only have 11 bolts not 13 which would make it a Romeo, yes, no, you got a mess there OLD H2S.
The 4.6 L 2V has been built at both Romeo Engine Plant and Windsor Engine Plant, and the plants have different designs for main bearings, heads (cam caps: interconnected cam "cages" vs individual caps per cam journal), camshaft gears (bolt-on vs. press-on), valve covers (11 bolts vs. 13 bolts), crankshaft (6 bolts vs. 8 bolts), and cross bolt fasteners for main bearing caps.[5]
From https://en.m.wikipedia.org/wiki/Ford_Modular_engine
The windsor name also applies to the mod motors also. .As far as I know, 95 was the last year of the Windsor. 96+ where all the mod motor. Not sure about the VIN with the X. You sure it doesn't mean something else?
Ultimately, in 1991, Ford began phasing out the Windsor engine and replacing it with their new 4.6/5.4 L Modular V8 engine. In 1996, Ford replaced the 5.0 L (302 cu in) pushrod Windsor V8 with the Modular 4.6 L in the Mustang
You taking it the wrong way. . The 4.6 has two classifications winsor and romeo.. not that its part of the winsor sbf family.. alot of parts are specific to either the romeo or winsor..
