Windsor swap
EWBTus
Az
All
Brand new to the forum. I have a stout 408 Cu In Windsor and a C4 that needs a home. I have 2 options at this point. Both are 4.6 L cars. One is a convertible with a 5 speed manual and the other is a coupe with a automatic. Both have blown engines and, as far as I know, good transmissions. The Windsor is shorter that the 4.6 l but QA1 has all the parts to put the motor in the car but we all know that is the easy part. I am more concerned with all the other stuff. Current Windsor is carbureted, gauges in the 2 mustangs are expecting digital inputs. So, the 3 options as I see it are 1) put in the Windsor and the C4 and deal with the gauges, electric fuel pump, etc., 2) use one of the transmissions with all that comes with it - bell housings, clutches, converters, flywheels, flex plates, etc. or 3) upgrading to a better manual. I know this is over simplistic but also know that I am not venturing into unknown ground. SN95 mustangs are great cars. I bought my wife a 2005 Mercedes SL-500 for Xmas and after dumping 15K into it to make it perfect, she is granting me permission (40 years married so you know what I mean) to build up a Mustang. I really want your experience. I am too old to think I can figure out all this on my own. Thx
E
EWBTus
Az
What years are the cars
and year of Windsor Motor
The convertible with manual trans is a 2003 and the coupe with a auto is a 2002. Not sure the age of the motor. If I recall it came out of a 90's truck.
RAU03MACH
NEW MEXICO
later 90s and early 90s still a big difference
take some pictures of the block mostly the top
then take one of the passenger side of block, bottom towards the front there will be a part number
year description
E
EWBTus
Az
I was wrong. The motor code is D4AE-6015-AA-13 which is a 1974 block. It is running a retrofit hydraulic roller from Comp cams. Scat crank with Mahle forged pistons at 10.2 static compression. Edelbrock air gap RPM with an 850 Edelbrock AVS2.
E
EWBTus
Az
52-93 is what is
You're planning on installing this in one of the cars right
just checking
Right now it look like the 2003 convertible is the winner. Best interior and only minor issues on the paint. Has a T3650 manual which, as I understand it, only fits a 4.6L mod motor so I will be using my C4.
RAU03MACH
NEW MEXICO
I will be so glad when mine is done
i just about got everything accomplished on the projects that must get done
my roof on my building is just about complete 2 more sheets and then seal the whole inside of it
and then for the truck i need to take the front of engine apart and replace oil pump timing chain kit seal kit
then i should be able to start on my engine
one thing at a time
just trying to get all the shit out of the way.
but yes a 351 is going to be excellent
jrfitz63
Staff online
