Wiring question
bad horc
I have a 97 GT automatic. I'm thinking about possibly putting a 3650 in it.The 5 speed is out of an 01 Cobra. Does anybody know what transmission wiring harness I would use on this swap?
1996mustangGT
the biggest problem i see is that the early sn-95's
(94-97ish) all use mechanical speedo's....the post 97 all use electronic
speedo's. I THINK there is a conversion you can get from FRPP but to be honest i have
no idea if that'll work....as for the harness you'd need the one from the same (99-01) cobra.
call up FRPP or someone similar they'd know what youd need...
scarface
Guest
the dallas mustang speedcal EXT will take care of the speedo problem. I put a t45 out of a 99 coba in my 97 gt, and used that. Worked great.
Im not sure what transmission wire harness you are referring to though? The only harness on the 5spd in the electric speedo (that I can remember)
95Five0
