Won’t go into gear before and after new clutch and clutch cable. Please help!!!
Grimm
Need help please. I have a 00 Mustang GT i just bought a few months ago. Drove great with no major problems and no leaks. I did drive it hard because it’s a fun car and drove it a lot everyday. I have no mechanical experience. One day it wouldnt go into gear so i tightened the cable and that worked. Shifted even better than before. Then some weeks later it wouldnt go into gear again so i tightened the cable again but no matter how tight i did it, it still wouldnt go into gear until i think i did it too tight and it started squeeling really loud. I look in the transmission and see that the TOB was loose and sitting on the clutch fingers off centered. So i install a clutch, pilot bearing, TOB, and clutch cable myself but the problem is still the same. The flywheel looked good still so i left it but really not too sure. Nothing was installed backwards, everything is right as far as i know. I was careful to make sure of this and my friend whos a mechanic came and took it all apart to check my work but everything was fine and he cant seem to figure it out. So im kinda stick right now trying to figure it out on my own. Through my research im thinking its the synchros. And thinking about doing it myself because i cant afford a rebuild right now. Was told it had an engine swap and transmission seemed good. Says over 200,000 miles but idk. Had an aftermarket clutchquadrant, firewall adjuster, clutch cable, and short throw shifter already when i got it. I also changed the transmission fluid. Also when i try to force it into fear it will so to go in but then start grinding really hard immediately. The squeeling noise stopped after i adjusted the cable. Ive tried adjusting the cable up and down across the board but still nothing. Oh and also it goes into gear with the car off. And before i put the new clutch if i would put it into 1st then start the car it would jump the car forward. Sorry this is so long im just trying to be informative. Any advice would greatly be appreciated because i dont have anything else. Thank you.
Methodical
Wow, you got me on this one. It seems you've tackled some of the things I would've suggested and more.
The one time I had an issue with the clutch going into gear the cable under hood was frayed and had to be replaced. It somehow was touching the header.
96blak54
Staff member
Lawrenceburg Kentucky
This is just an idea. I know the clutch fork can be installed in a wanky situation, easily over looked and actually function as normal. Where the fork engages onto the pivot ball, it could be off but still holding on with the retaining slip springs. I would imagine problems you described would mimic that scenario. Be sure the fork is properly seated on the pivot ball correctly.
Miltoid
Don't tare into the tranny just yet. Bad synchronizers won't keep it from going into gear initially. Will it go into gear if the engine isn't running? If so the clutch isn't being disengaged. Have someone apply the clutch while you watch the fork, engine not running. Watch for full movement. I would suspect the cable.
SPeace-ATL
A very common problem with any Mustang Manual transmission with a factory 10-spline input shaft is that with hard launching with a strong clutch the input shaft can twist a little, or even shear completely off the front of the transmission right behind the clutch. The symptom is difficulty getting it into gear with the engine running. It is as if the clutch cable has stretched and the clutch isn't releasing fully.
What is happening is the twisted splines don't allow the clutch disc to "float" on the input shaft. This causes the clutch disc to still be pressing against the flywheel even when the pressure plate has fully pulled away.
The fix for this is to replace the input shaft with a custom 26 spline input shaft. And, of course, get a clutch with the matching 26 spline hub.
alexstang28
