Wonky odometer
Fauxbra03
Phoenix
I’ve only had my new edge for a couple months now and as of 12/24, I put in led lights for my gauge cluster. After I finished that, I had to drive to the store and on the way there I realized whenever I press my brakes, the digital odometer turns off. Now this only happens when the lights are off, if the lights are on, then it won’t do it. So basically, touch the break pedal, the odometer turns off, let off the breaks it comes back on.
I really have no idea why this would even happen so I figured someone else might. Thanks!
Paladin1001
Sounds like a grounding issue. I wonder if the LED lights don't ground like conventional bulbs. Try running another ground line to the cluster and soldering it in.
bs.austin.tx
