Working on Grandpa's 19k Mile 98' Cobra - Broken Transmission Part
JM280z
Hey All,
I just got my grandpa's 19k all original 98' SVT Cobra. He passed away about a year ago. I grew up going to car shows and out to dinner in it with him, fun car! Well, it sat for the last couple years, and it turns out the fifth/reverse lockout arm is broken. The pin/bolt that it sits on was screwed halfway out already and when I tightened it back in I could hear the arm swing down inside. F6ZZ-7K002-A is the part number. I can't find this part anywhere. Suggestions?
On a side note, my wife is helping a lot with it so she will be allowed to learn manual in it. We've done: ball joints, inner and outer tie rods, brake lines, rebuilt the calipers, rotors and pads, ignition coils (oem Motorcraft), spark plug wires, spark plugs, cleaned MAF / throttle body / intake manifold, air filter, engine oil, radiator fluid, power steering fluid, diff fluid, cleaned and painted the diff / drive shaft / diff counterweight, new tires, and probably forgetting some.
lwarrior1016
Mr. Secondary Timing Chain
Staff member
South Mississippi
Are you rebuilding the transmission or just fixing that part?
You could also call Stan at Pro-force performance. He is the man when it comes to these things.
lwarrior1016
Staff member
South Mississippi
You could look in to Stan’s billet 5/R shift fork. He’s got a single disconnect design that synchronizes reverse and lets it go in much easier.
J
JM280z
Thanks! I emailed Stan and will ask to buy oem or billet (preferred).
Gurdy
