Would you do Plenum and TB or CAI first.
ck5.0
I have a P.I. 96 GT. I was wondering about some opinions. I was thinking about getting a JTL CAI for $205 or the ProPerformance Plenum and TB for $224. What are your thoughts on these two options.
97vertstang
well i dont know much about the pro plenum, but in my cousins car we installed a trick flow plenum and bbk 70mm tb, and it was a bigger improvement than the cai.both though wont gain u much though.
C
ck5.0
Thanks for the info. Muscle Mustang did a shootout of TB's and Plenum. I was never impressed with ProPerformance before but it produced only 2 less RWHP than the Accufab that they tested and it is almost half the price. Neither of these two things are big HP gainers but just first on the list of bolt ons. Thanks for the good info. Is there anyone actually running the JLT CAI or the ProPerformance Plenum and TB?
jpajkos
save your money get some cams. Cams, gears and full exhaust = a much happier driver. I will be selling my plenum, tb, and cai here by the end of december.
scarface
Guest
I didnt notice any seat of the pants difference with either ??? SO I guess its which ever you want the most.
Dalamar
SLC, UT
I would go for a power part.
Cams, gears ect.
The gain's NA are a waste of money, I've done both.
Just remove your air silencer, thingie. Maybe get a Good filter and save up for the good stuff.
jpajkos
I mean like I said bro when it comes to bolt on's the biggest gains for the money are going to be Pullies and a good mid pipe. Everything else is very minimal.
C
ck5.0
Thanks for the info guys. On my Fox body with a new throttle body, upper and lower intake there was a big difference. I am seeing that this 4.6 is a different beast. I am going to go with your suggestions and pick up some pullies and a mid pipe. Thanks a ton. I have waiting to be put in, gears, Flows, 155lb Fuel pump, fuel pressure reg, msd box.
Just another reason why I am new but already a supporting member, everyone here is great and really likes to help.
Dalamar
SLC, UT
We're glad you like it here.
Definately do Gears Asap. they're probably the best feel-for-power mod there is. ;D
DropTopPony
South Jersey
4.10's/mid pipe/speedcal should be the first mods on a 4.6...they actually work. Now since you are already PI swapped a TB/Plenum setup will benefit you down the road. Look around on ebay and www.corral.net for great deals on used ones.
jpajkos
Good choice ont he pullies and mid pipe. :thumb: Once you read up alittle bit you will know that cams and gears will make you pony really wake up.
AaRoN
King Post Whore
Yes definitely gears. Those are next on the list. Cams are something that I really want but those will come with the P.I. Swap.
dutman98
I thought that my 4.6 would benifit from getting a port and polish pleneum and 70mm t/b. I did not notice any diffrence at all :-X........I got my gears(4:10's) and noticed a huge diffrence. I would go for gears first :thumb:
jpajkos
A port and polish is noticeable only really at higher rpm levels. My car breath's so much better with my ported heads. If you can work alittle bit on suspension. Power don't mean shit if you can't plant those wheels on the ground. Trust me im going through that already. I know for a fact everyone will agree with this aspect.
AaRoN
King Post Whore
+1,000
98armygt
GEARS, GEARS, GEARS. that right there is gonna be your best bang for the buck. thats my .02 cents.
scarface
Guest
ck5.0 said:
I was thinking about getting a JTL CAI or the ProPerformance Plenum and TB for . What are your thoughts on these two options.
you guys have steered from his topic....He was just asking about these 2 options.
Vmarch
