347 Stroker Build
95_GTS
I'm currently in the process of getting a 347 SCAT Stroker Kit installed in a Dart SHP SBF (8.2" Deck) for my 95 GT 5 speed. That said, I am looking for a CAMSHAFT to compliment this build.
AFR 185 Renegade SBF heads
CCA 1.7 Roller Rockers (Intake/Exhaust)
Ported Ford Explorer Intake (Bench flow tested @272 CFM)
BBK 75mm TB
FRPP 60# injectors
Pro-M MAF 92mm (Calibrated for 60# injectors)
FRPP 3.73 rear end
315/35r17 MT Street Comp Rear Tires (25.6" tall)
In addition, it will be supercharged soon after break-in period.
Thanks in advance
07GtS197
Fort Myers, Fl
I saw your thread on the corral. Not talking down to anyone on this forum as there are many knowledgable people on here, but I’d reach out to Ed Curtis over there. Grinding cams is what he does.
95_GTS
95_GTS
Do you happen to know his turn around time to get the cam?
302hobronco
Washington
What computer system you going to use to run everything? Your cam will need to be compatible with your computer system.
Musturd
Check out Anderson Ford motorsport for good off the shelf cams, or Ed Curtis for a custom cam.
Getting your hands on a Anderson cam right now is damn near impossible . Talking with Donny last week I think he had a couple b31’s left and that was it
302hobronco
Washington
I had Rubens racing cams, out of Anaheim cali custom grind a billet cam for my 331. Give him a call.
highplace11
