1998MustangVert
Buffalo, NY
Hi everyone. I have a 98 V6 convertible. 132k miles. I currently have the factory automatic 4R70W in it and I want to convert to a T45. I have no issue flashing the PCM as a manual so no problems there. I’m trying to get a parts list together to figure out what I need to execute the job. Currently attending tech school and will be a guided project but I want to be as prepared as possible. Thank you all in advance for the tips!
white95
Apex Junky
Admin
Prairieville, LA
well...
T45
shifter
shift knob
shifter bezel/boot for interior
clutch
clutch fork
throw-out bearing
pilot bearing for crankshaft
manual transmission pedal box
clutch cable
driveshaft
transmission crossmember [recommend Stifflers]
transmission mount
engine plate
dust cover
You exhaust *should* fit the manual transmission stuff but we may need clarity on this.
weendoggy
well...
T45
shifter
shift knob
clutch
clutch fork
throw-out bearing
clutch cable
driveshaft
transmission mount
engine plate
dust cover
...and a flywheel (maybe) :p Yeah, I know, it's Monday.
1998MustangVert
1998MustangVert
Buffalo, NY
well...
T45
shifter
shift knob
clutch
clutch fork
throw-out bearing
clutch cable
driveshaft
transmission mount
engine plate
dust cover
Thanks for that info! I’ll hopefully be doing this swap in the spring.
