Highlighted posts from Friday, Aug. 12, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
August 11, 2022 * 7 posts * 40 views
NicksGTR said: So I wanted to remove my steering wheel on my 01 Bullitt. Got the wheel puller out, tightened the bolts into the pot metal and slowly turned the the center bolt to apply pressure ... Read more >>
August 11, 2022 * 10 posts * 81 views
TrickVert said: Another vote for Aerospace 303 protectant. Be sure to follow the directions, though, and wipe it down with a dry cloth after application otherwise, rain can make it streak down ... Read more >>
August 11, 2022 * 13 posts * 128 views
joemomma said: I got mine at China Freight. Cheap, and worked well enough for what I needed it to do. Read more >>
August 11, 2022 * 8 posts * 113 views
lwarrior1016 said: Good idea. DiyAutoTune has a plug and play megasquirt for our cars. They tune really easy, so that could be an option too. Read more >>
August 11, 2022 * 8 posts * 149 views
thaliabobalia said: Thank you all for your feedback and input. I think I may go for an AEM dryflow in the stock box if I can find one. Read more >>
August 11, 2022 * 3 posts * 30 views
Blueraz_5.0 said: So I have the aluminum crossover intake for the NPI 4.6. I was running the stock alternator and bracket for a while, (then replaced the alternator) and ran it for 16k miles), and ... Read more >>
August 11, 2022 * 27 posts * 279 views
joemomma said: Great, something else on the never-ending list of things my heap needs lol. Read more >>
August 12, 2022 * 1 post * 6 views
SN95Newsletter said: Click here to view on the web Highlighted posts Question for you Vert People August 10, 2022 * 5 posts * 34 views Exterior and Interior Shift knob August 10, 2022 * 12 posts * ... Read more >>
August 11, 2022 * 7 posts * 191 views
95GTS5L said: Went Good. Experienced some idle up issues and stalling after but seem to have fixed those by changing to a 160 t-stat and Ford coolant Tube sensor with different new harness plug. ... Read more >>
Continue reading...
RevJon
