Highlighted posts from Tuesday, Jan. 25, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
January 24, 2022 * 41 posts * 269 views
lwarrior1016 said: I thought only the 98's had a relay behind the glove box? Either way, the resistor and second relay is made to make the pump sort of a two speed setup. If the relay is not energized, ... Read more >>
January 25, 2022 * 26 posts * 293 views
Gregomatic said: Chuy said: Michael and Chuy are on point with my feelings. If I were in your shoes, I'd give it a break. Rarely does much good come from a decision that wasn't pondered if time ... Read more >>
January 24, 2022 * 11 posts * 87 views
D3VST8R96GT said: Find a good cleaner and a conditioner that are separate. I use lexol cleaner and griots garage squeeze bottle conditioner its at vatozone and on amazon. I found some mach 1 seats ... Read more >>
January 24, 2022 * 6 posts * 59 views
joemomma said: Why are you wanting to tune a stock car? I had similar questions about Ted/TI (as I came across his name mentioned quite a bit on the interwebs), but learned that he isn't well-regarded ... Read more >>
January 24, 2022 * 10 posts * 68 views
Randall Garner said: Upr has a SN /newedge SBF K MEMBER. I have one in a 98 coupe with 351. Works fine. Read more >>
January 24, 2022 * 57 posts * 539 views
ttocs said: the story I read was that msd was had a LOT of counterfeit parts that were put out in the market that the cases looked almost spot on but the internals were not the same at all ... Read more >>
January 24, 2022 * 1 post * 11 views
RockAuto said: Wholesaler Closeout parts are our "clearance rack." The parts were acquired at discounted prices from companies liquidating inventory (because they were overstocked, decided to ... Read more >>
January 24, 2022 * 1 post * 10 views
SN95Newsletter said: Click here to view on the web Highlighted posts 96 cobra breaks up under WOT January 23, 2022 * 25 posts * 156 views General Tech Thinking of selling my 95 GT January 23, 2022 ... Read more >>
January 25, 2022 * 2 posts * 11 views
Flade said: It's well documented that when the Mach 460 gets older the amps can fail in a way that causes a parasitic draw on the battery when the car is turned off. What I have not been able ... Read more >>
January 25, 2022 * 1 post * 10 views
rickedeke17 said: They are so appealing and addicting to watch Asian women porn videos....I always watch them here at asian porn websites by [link] For sure, you will watch asian sex here until ... Read more >>
Continue reading...
RevJon
