Highlighted posts from Wednesday, Jul. 14, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
July 13, 2021 * 24 posts * 196 views
Daryl said: I like it! I read through the entire 4-page instructions and after installing it "as is", I found it still a bit heavy and cumbersome between shifts. So,I did go back and remove ... Read more >>
July 14, 2021 * 9 posts * 42 views
96blak54 said: From what ive heard, comp receives old and odd cams for a regrind all the time. They the big dogs of the cam business. Cams that are claimed " off the shelf ", like what you have, ... Read more >>
July 13, 2021 * 11 posts * 74 views
lwarrior1016 said: You might be able to get it underneath with a swivel socket and a super long extension (I've got a 3' extension for transmissions). You might be able to drop the transmission crossmember ... Read more >>
July 13, 2021 * 1 post * 9 views
SN95Newsletter said: Click here to view on the web Highlighted posts Comparing shifters July 12, 2021 * 17 posts * 124 views 94-95 5.0 - Specific Help with swapping the coolant tube: PI Intake Swap ... Read more >>
July 13, 2021 * 4 posts * 70 views
ttocs said: I would consider swapping out the vac lines with that milage while things are out and easy. I was about to say inspect/replace but you will have problems seeing the really small ... Read more >>
July 13, 2021 * 15 posts * 453 views
Randall Garner said: Thanks for all the advise. Did compression test. All within a couple # of each other. New coils, wires, plugs and injectors. Car runs nice. For something that sat for 8 years. ... Read more >>
July 14, 2021 * 23 posts * 1,688 views
castine917 said: Lost my favorites while computer swapping. Found this while looking for another. This has a nice balance of play and real in a very short video. [link] Read more >>
Continue reading...
RevJon
