The machine is a monster! Bismuth steel is used as the negative for plastic to be injected over and then melted out. So that means 2 mold process are involved. One for the bismuth negative and one for the bismuth negative to sit in and plastic to be injected over. Then its dipped into an electricity tank of a special solution that melts out the bismuth negative and the intake at this point is something north of 200pounds. Robots do all the handling. Its a monster of a machine that requires a dedicated team of experienced employees to operate.
It was the plastic 4.6l manifolds, npi and pi, that put this company on the map. Literally millions of manifolds were produce from 2 machines and this machine is the remaining one.
The reason why the plastic aftermarket replacement intake are terrible for performance is the runners dont have the same space and not the same shape. Mostly space due the the manifolds being 2 or 3 components the sonic welded together. This one piece plastic save all the necessary space for proper tooling needed to weld the multiple components together.
