January ROTM!!
Status
Not open for further replies.
So, As an apology to our contestants this month, the winner will win either:
2 small window stickers or 1 large SN95 Forum sticker
(Your choice, winner!)
Mod List:
2.2L Kenne Bell Supercharger with Flowzilla inlet
AFR 165cc Cylinder Heads
Steeda #19 Cam, 1.7RR
Mac 1 3/4" Longtubes, Prochamber, Borla Stinger catback
FRPP Diff / 3.55 gears
Moser 31 spline axles
Spec stage 2 clutch
MM K member, A arms & Coilovers
MM Camber plates
MM rear lower control arms
H&R SS rear springs
Vertical tail lights with sequentials
OEM Cobra R hood
HID headlights and fogs, LEDs inside and out
Cobra grill emblem, wiper delete, shorty antenna
a306juGRnot
1987 ford mustang lx coupe
Mod List:
70mm throttle body
30lbs maf/injectors
edelbrock rpm 2 intake
edelbrock rpm heads
crower cam
255 walbro fuel pump
msd ignition coil
shorty style exhuast manifold
off road x
IRS magnaflow catback
full IRS swap with stock cobra 355 gears
aluminum drive shaft
tubular k member (with stock a arms)
eibach pro kit springs front w/tokico struts (1coil cut)
h&r ss springs rear w/stock cobra bilstein shocks (1coil cut)
95 cobra r cowl hood (cervinis)
mach 1 chin
XXR 521 wheels (18x10 all around)
255/35 all around bridgestone rft
thank you to all whos given this car love...its still an ongoing project of mine and will be finished soon. i will be at FAB FORDS car show this year in april to hopefully enter her in. thanks!
JeremyAlan
2004 Screaming Yellow Cobra
Mod List:
-M122 Blower swap (2.76 upper/+4 lb lower = 19lbs of boost)
-Cobraengineering.net adapter plate
-Dragon Throttle Body
-Rebuilt motor w/ Manley Pistons (9.1:1) w/ stock crank and rods
-60 lb/hr injectors
-Boost-a-pump
-Steeda Tri-ax
-Anti-Venom Mod
-Custom 4 Muffler 3 inch exhaust w/ 1-off H-pipe
-Diff brace
-Subframe Connectors
-Eibach Pro-kit Lowering Springs
-18x9 & 18x10 Anthracite FR500's
Mod List:
90mm Lighting Mas Air Flow sensor
Anderson Power Pipe
Ported cobra Upper intake
1/2" phenolic spacer
Ported 1994 Cobra lower intake
Trickflow aluminum 170cc twisted wedge heads
Trickflow stage 1 cam
SVO 1.6 roller rockers
ARP fasteners top end bolt kit
MSD ignition coil
Taylor 9mm spark plug cables
BBK shorty headers
Magnaflow high-flow-catted x-pipe
Dynamax side exhaust mufflers
SVO Style Side Exhaust Skirts
Mach 1 chin spoiler(soon to be shinoda)
HID headlights with projectors and HID fog lights, black parking lights, smoked tail lights
Adjustable ride height from Ridetech E3 air ride system
Ridetech E3 auto-leveling air ride system
Ridetech Shocks/struts
-Custom made A-pillar and Steering wheel gauge-pods for 3 PLX designs digital gauges(2 touchscreen) showing 4 different sensors(build pics for the steering wheel pod available here: http://www.cardomain.com/ride/239542...upe-2d/page-8/)
-Custom padded/wrapped steering wheel from Redline Leather Goods with polished billet cruise control switches
-Matching leather shift boot(with green stripe)
-Matching leather parking brake boot
-Matching leather arm rest cover
-Custom rear seat delete with areas underneath for audio gear still being installed.
-Crazy custom stereo still under construction - build page detailing the process is here - http://sn95forums.com/showthread.php...t=stereo+begun
-Installed explorer overhead consol and flush-mounted the Ridetech E3 digital display into it. The tank, valves and CPU for the system were also mounted inside and the install is shown here: http://www.cardomain.com/ride/239542...upe-2d/page-6/
-microsuede with green stripe on the overhead covering
-custom molded a Passport Escort 9500ci radar detector(with laser shifters) into the clock pod and the speaker into the mach tweeter location, control panel flush mounted in the coin holder
-Custom switch bank in the ashtray
As for the changes I have already done to it there is just not enough space here to list them all.
[video=youtube;-ZTMA_wxwAM]http://www.youtube.com/watch?feature=player_embedded&v=-ZTMA_wxwAM[/video]
stprorolla49
Mod list:
Paxton Novi 2000
CX Racing intercooler w/ 3" intercooler piping
VMP HPX MAF
Aviator pump
KB 20a BAP
FRPP 39lb inj
Vortech Maxflow BPV
Moroso PCV tank
Moroso coolant overflow
Borla Stingers
Magnaflow catted x-pipe
Maximum Motorsport c/c plates
Maximum Motorsport front coilovers
Hypercoil 250 lb front springs
Bilstein HD's
Built '03 Cobra IRS
FRPP 4:10 gears
FRPP IRS diff cover
MM urethane IRS bushings
Rotorpros Dimpled/Slotted zinc coated rotors
Hawk PC pads
Brothers Performance Speedcal
18x9 & 18x10 Bullitts w/KDW2's
Mach 1 Chin Spoiler & Grill Delete
Summit Short Throw Shifter
Smoked Foglight Housings
DDM Tuning 6000k HID's in Headlights & Fogs
Autometer Sport Comp gauges
Speed of Sound Pillar Pod
Cluster LED's
On-In-60 Bullitt Coin Delete
Tinted Taillights
ProKiller
Mod List:
DSS 331
AFR comp 185 heads
AFM B-21 cam
Edelbrock performer RPM intake
Vortech V2
ceramic long tubes
dr. gas x
T-3550
alum driveshaft
3.73s
LEDs
c2 gauges
some stereo stuff
ABC exclusive's GTR front bumper
roush side skirts
cervini cobra R hood
saleen T1 spoiler
all painted true black with ghost blue pearl racing stripe
Orange 94
Mod List:
4.2 v6 (1998 F-150)
M112 Supercharger w/2.93 pulley
SSM adapter Plate
Mild ported split port heads and intake
Comp Cams 259HR115 cam
Comp Cams 26918 valve springs
Scorpion 1.73 roller rockers
Lightning 90mm MAF
C&L boost pipe
Walbro 255lph pump
Cobra Blue 39lb injectors
94 3.8 v6 stock headers
94 3.8 v6 25% underdrive pulleys
Double roller timing chain
Stock polished valve covers
T5 transmission (95GT)
Cobra clutch
Stock clutch cable
Triple hook quadrant/ locking firewall adjuster
Mac shifter
8.8 fox diff assembly 3.73 gears
00’ Mustang interior
Alpine stereo
Collection of Pool Ball shifter knobs (favorite: orange #5)
Cobra clear headlights
Stock horizontal taillights
255/35ZR18 Hankook Venture Plus front
275/35ZR18 Kohmo rear
Paint: 94 Ford “Bright Orangeâ€
HAL Kmember
QA1 CC plates
Eibach Pro- kit springs
Tokico D Spec Shocks Struts
Front FRPP Control Arms
AM UCA and LCA
Mac Cat Back w/polished tips
Pacesetter H-pipe
95riosnake
1995 Mustang Cobra coupe
Mod List:
Fordstrokers forged 347 stroker, 10.6:1 CR
Scat forged crank
Scat forged I-beam rods
Probe SRS forged pistons
Holley SysteMax heads
Holley SysteMax intake
Scorpion 1.6 roller rockers (7/16" stud mount)
Canton 7qt road race oil pan clearanced for 94/95
Accufab 75mm race TB fox conversion
SCT BA-2600 maf
SCT 4 bank eliminator chip
Ford Racing 42lb injectors
Russell -6an fuel lines
Aeromotive 340 Stealth pump
GZ Motorsports VP102 Sportsman vacuum pump
Fluidyne aluminum radiator
XRP -20an stainless hoses
CSR -20an swivel water neck
CSI Overflow Bottle
Procharger D1SC, 9psi 3.35 pulley
Procharger sheet metal 3-core intercooler
Custom built piping/power pipe
Race Mart 50mm blow off valve
MAC Jet Hot coated 1-5/8 long tubes
Custom-built X pipe
Borla Stingers
Custom built side pipes with Borla side exhaust tips
Built Tremec 3550
26 spline McLeod RST twin disc clutch
McLeod Flywheel
Ford Racing aluminum D/S
03 Cobra IRS, 3.55 gears, smoothed and powdercoated
Complete FTBR delrin bushing kit
FTBR extreme duty toe links
FTBR sway bar links
Front/rear cobra anniversary brake calipers
Baer D/S rotors
Tokico D-Spec struts
Team Z coilover kit
350lb Hypercoils
Maximum Motorsports tubular A-arms
Energy sway bar end links and rack bushings
Bilstein HD shocks
Maximum Motorsports coilover kit
550lb Hypercoils
CHE rear shock tower brace
SpinTech subframe connectors
SVO side exhaust skirts
96-98 export taillights
97 Cobra rear bumper cover/ stainless inserts
HRE 542R wheels, 19x9.5 front, 19x11 rear
Toyo 265/30/19 front and 295/30/19 rear
Sparco Evo2 seats (Corbeau TRS's shown in picture)
Schroth Rallye Cross harnesses
Redline Goods shift boot
Carbon fiber interior kit
Sinis Engineering cluster trim rings
Autometer C2 DPSS, oil pressure, boost, water temp, and volt gauges, AEM wideband
Alpine head unit
Boston Acoustics components in doors
Boston Acoustics 5x7's in rear
Boston Acoustics G5 10" sub in custom box
Kenwood 1000w mono amp
495rwhp/494rwtq
Musturd
306jugrnot I wanna see a fox coupe up there because the month I lost too had been up forever
KillNThrill24
Cleveland Ohio
I swear it seems every month it gets harder and harder to choose lol. But I have to say ProKiller's car was the first car to make me realize that not all SN95's are ugly. The aggressiveness his car has is just plain awesome. No to mention Vortec on a 5.0 = win. Your gettin my vote buddy!
I'll get you next time Orange :)
Tony
ohio
really wish orange94 woulda posted better shots of his exterior. i know his paint is on point and the fact that he made a 6er nasty as hell impresses me. i vote orange :)
belber095
Ithaca, NY
I voted orange for going a different route than the norm and doing something with that that I've never seen on an sn95(minus mc) on a sixxer!! Hes got a unique color and can pull off bullits pretty nicely. Guys got my vote for sure.
tapatalkin'
KidK9
Cincinnati, Ohio
No offense to rio bc we all know his car is god, but the dude has won twice already with once being 6 months ago. What gives?
Tony
ohio
^lol, yea i agree. i'm sure he wont mind others gettin some love this month. he knows wassup, lol
stprorolla49
Fairfield, CT
Even though I know he is gonna win, I gotta give the vote to Dan (95riosnake). His car never ceases to amaze me. I always pick up on new details that I missed the last time I saw pics. Simply amazing, I wish my car would get to that level at some time in my mustang life hahaha!
Shifty Powers
Where the wild goose grows
I vote for orange. Almost everyone else up there has been nominated month after month and has won within the past year or so.
Also its more incentive for him to send me my canadian stuff!!! Woooo
Tony
ohio
man wtf is up with dans steel braided hoses all in perfect condition, lol. i tried that shit and it looked like i drug it behind my car first. like dude spent 15 hrs strictly on his hoses. not to mention his 9 intake tubes, lol. fuggin motor is clean geeez!
actually I am a virgin here as well in the ROTM....
ProKiller
PA
i voted for you scott. you need some lovin after all that work.
Orange 94
Alberta Canada
Thanks guys! Tony, I will get better pictures in the summer! We were also resricted to 2 pics so it was a hard choice for me...
Such beautiful cars... my vote goes to JeremyAlan. I'm a sucker for a yellow 04, and its so nicely done and clean.
g36 monkey
Orlando, Fl
Voted for Scott. The pictures do his car zero justice.
Glad I'm not up this month, I'd be obliterated.
Rio knows I have a deep love for his car though :)
Eh, I love all the ones up for this month, but I love TTOCS interior customization. Second to none.
January's ROTM was the "no rules" month. The members were allowed to nominate any member they wanted regardless of past rules and regulations. The entire nomination group from the previous month (November) was also nominated, but we ran short on space...
Regardless, Rio was selected by the members -- I give the people what they want :)
No worries, we'll be back on the standard rules for February.... :-D
KillNThrill24
Cleveland Ohio
Scott I love your ride to man. It was real hard to choose but Pro's car was the first SN I saw that I liked on here! Don't be shy bud show off that sweet ride of yours! :)
Sent from my Galaxy Note 2
I wouldn't even be able to pick a car this month.
and what gives on the mods lists that were supposed to be abbreviated? some of those are massive lol
I just gave a link to my cardomain page when he said he needed it shorter. Its in my sig if by some strange chance someone has not seen it yet.
Status
shagg9
