Lunar Shadow '93 Coupe (non-SN95)
RedTwilight
RedTwilight
Roxboro, NC
Next up:
I did replace the passenger exterior door handle and the driver side door latch. While I had the door panels off, I took the opportunity to replace the inner window dew wipes and the map pocket delete panel.
Then I cleaned it up inside and out in preparation for "Not" Mustang Week 2020.
It turned out to be a GREAT event! It was just as packed with Mustangs as if everything was normal.
Then we had almost perfect weather for late November in the low to mid 70*'s and low humidity. Not knowing if such a day would come again anytime soon, I took the opportunity to paint the brake calipers for the 5 lug Cobra disc swap.
They were painted Ford Green Gem Metallic using 2K epoxy primer, 2K basecoat, and 2K Gloss Clear in spray cans. This is the same color that I plan to repaint the '93 with.
This rounds out 2020.
RedTwilight
RedTwilight
Roxboro, NC
So in April 2021 I finally got the 5-lug Cobra brake Conversion done! It was a bit of a thrash to get it done last minute before the annual Easter Race at Roxboro Motorsports Park.
While I was at it, I also installed new Strange 10way single adjustable shocks and struts, and got the Line Lock plumbed in.
Here it is with the RaceStar wheels at the track.
Line lock switch on the shifter handle
I also managed to get a new best time of 8.35 in the 1/8th mile at 80mph.
RedTwilight
RedTwilight
Roxboro, NC
Just before going down for Mustang Week I got the parking brake cables and handle installed. The handle is from an SN95 Cobra.
Now I need a new boot for it and the shifter bezel.
Couple of pics of the coupe from Mustang Week 2021.
On the way back from Mustang Week 2021, my 4 hr drive turned into an almost 8 hr drive after the smog pump delete pulley decided it wanted depart on Hwy 17 just outside of Wilmington.
I finally was able to get a ride to the nearest parts store (that was a 15 minute drive away) to pick up a shorter belt. Unfortunately by the time I had made it home, this belt had stretched too much and was now coming in contact with itself at the tensioner.
So I ended up pulling the stuff off the front of the engine and giving it a good cleaning to remove all the bits of rubber.
Now that it was looking a lot cleaner under the hood, I decided to go ahead at this time and install the Speed Doctor Racing Components low mount alternator bracket.
And this pretty much catches us up to date on the car.
Cybbur
