03-04 heads
Tim300wsm
I found a set of complete 03-04 heads. I think I will pick up. What’s a fair price for a good set. If I can’t fix my cooling issue I will swap them.
Besides the intake manifold is there anything else to swap?
apsmith49921
You can get an adapter plate to use your intake top from a guy on svtp. Or you will need a throttle body cable which is hard to come by and offer expensive. I'll find the post for you if you'd like
You need to modify the fuel rails and coolant crossover. And of course all necessary gaskets
Also it will need a tune. Timing is slightly different and the ecu will also not advance timing correctly after 3500 rpm if you don't have the IMRC which you will not
As far as a fair price it's hard to say you need to find out which casting they are. You will want the DC casting if possible. They're the final revision.
once there machined and rebuilt oh ya big money
mmr 1500 per head
mod max 1200 per head
livernoris 13 per
Tim300wsm
Tim300wsm
mmr 1500 per head
livernoris 13 per
I’m hoping they don’t need much rework. I need to find a good shop to bring them to.
Tim300wsm
Tim300wsm
A link to the adapter would be great
Well if your going 03 04 heads you won't need the intake runner plates
You would need a mach1 intake and fuel rail for it
I just did a complete 2 v to 4v swap
There are a few things to change
But not like I did
The swap i did is in the
What did you do to your car today
I dont really like trying to put it all in 1 big file
I do as I get time and parts
Chivo Viejo
