1/2" wheel spacers...
Rice_slayer
Slykin
Tyler, Texas
Really what you want is a hubcentric but you can't get them that small... If I were you'd I would just get some wider tires for the back. It shouldn't be too hard to get them close to a half inch wider. If someone else has something just say something.
R
Rice_slayer
What's the smallest Hubcentric you can get? with 1" spacers, would I be running into tire/upper fender rub?
duff daddy
Don't buy those "ghetto" spacers, do a search and see, but the slip over spacers are junk get some nice hub-centric ones as these....
http://www.maximummotorsports.com/store/index.php?main_page=product_info&cPath=48_134_231&products_id=575
They are the ones I run on my car with my welds.
Do some research before you tell someone they aren't made....
95opal
If your only running a 1/2 inch those are fine just make sure you have 7 threads on your studs thats what is important. If you read MM site thats what they reccomend so dont listen to all the bs about having to run hubcentrics. Not needed in all aplications. Ive been running the same type spacer for over 10 years on a couple of different cars and have never ever had a problem. Dont be a victim of another ingternet myth. Just do the proper research and save your self a buck.
dafizuck
Agreed
Win
Kennesaw, Ga
I'm going with a 1" hub centric ones. Then when i eventually throw the 00r's on there i will just pull them off.
duff daddy
100% right but if he ever plans to take that car to the track, a good tech crew will scoot his butt off the track QUICK...I IHRA/NHRA/NMRA/NMCA all say no dice to lugcentric spacers for safety and reliability, then there is something I dont want to experience with someone in the car with me, nor have the possibility of doing something to someone else. If you can be safer why not do it. But you do make a good point you dont HAVE to, 100% his personal decison.
R
Rice_slayer
See there's the problem, I DO take my car to the track and run Slicks/ET streets, so I do need a hubcentric spacer. Anyone have pics of 275s with a 1" spacer by chance?
adrift
Hey Duff, do you know if the half inchers will be wide enough to be noticeable? I'm running OEM Bullitts that are, I believe, 17x8. I see a lot of folks running 1" and 1.25" spacers on their wheels, so didn't know if the 1/2" would even make much of a difference. Also, with 1/2" or 1/4" spacers do you need to worry about cutting studs? Seems to me you wouldn't since they probably slip right over the current studs. For reference I'm taking this video in consideration for 1" spacers: http://www.youtube.com/watch?v=G6Kiw8PD7Iw
GDTrumbo
Nashville, TN
If the car is originally designed with "hubcentric" wheels (as all Ford products have been for years as well as others), use only hubcentric replacement wheels and spacers if desired. The lugs will never center the wheel/spacer on the hub the same way twice on their own. Your just inviting new vibrations to the drivetrain.
GT
duff daddy
I do not know the answer to that, Im sure you would notice it, but a wide stance wont necessarly look great all the time.
I didnt cut studs, i added longer 3" studs on mine because of wheel/lugnut set up
Suprasuavy
