1998 mustang gas tank Q's/?
johnny
IS a 1998 mustang a specific year only gas tank? I need to change mine due to rust, however when I search for them they are usually listed as 86-97, and then 1999-04...
Thanks in advance
johnnyj
rz5.0
Great state of TEXAS
Yes. They are I'm actually contemplating switching to an early style on my 98. .
Enviado usando mi SHP-L710 usando TapaTalk
rz5.0
The 98 is not baffled. Uses a basket and a two speed pump..
The 98 is some what limited on fuel pump choices
rz5.0
Yes but it's not a straight swap. You can 99 newer but I'm not exactly sure how that goes. For 97 down you will need a gas tank filter neck and hardware. Swap the connectors. .. fuel lines going to fuel filter to gas tank. . Easiest would be to go to the junk yard. Get all the stuff. As far as I know 94-97 v6-v8 is the same. .
J
johnny
So could I use one from a different year? I.e. pull one from a 2000 and use that or a 1997?
rz5.0
Yes to can use one from a different year. If you do 99+ you have to get a different hat for the tank. . One for a return style tank. .
rz5.0
Ive also heard if you go the 97 down way you have to do something about the 2 speeds for the pump and set it on one. Im not there yet so ill have to find out as I go..
J
johnny
What about just using the pump assembly and hat on a different tank? It's just DD V6 convertible. I will not be upgrading it performance wise just the appearance side so I'm not worried about that side of the things. I just don't want to have a hole in my gas tank...!
rz5.0
Everything about the 98 is unique. . Where you at? In a couple weeks I'll be getting rid of my 98 gas tank. . Nothing wrong with it..
Chivo Viejo
