302 headbolt coolant leak
mike stevens
I had overheated my 302. warped heads, blown headgaskets. I got the heads ck.d and freshened up. reinstalled everything. I reused my arp headbolts. Which is supposed to be o/k. I have 2 outside drivers side bolts leaking water. I used engine oil on the threads, never had that kind of problem before. Should I be using teflon paste instead? Or is there another answer?
Mike
RAU03MACH
NEW MEXICO
Some of those bolts need pipe dope sealant
There the out side ones
And mabe the inside around cylinder water jackets
Wmac
Steeltown, Ontario
All of the lower bolts holes are open, into the water jackets and require sealant on the bolts. The upper head bolts holes are all blind and require lube only.
Superman3872
