7-second 1500hp street car build
94strokedstang
View attachment 3426 View attachment 3420 View attachment 3420 View attachment 3420 View attachment 3420 View attachment 3420 View attachment 3420 View attachment 3420 View attachment 3421 View attachment 3420 View attachment 3421 View attachment 3422 View attachment 3423 View attachment 3424 View attachment 3425 View attachment 3426 View attachment 3420 View attachment 3421 View attachment 3422 View attachment 3423 View attachment 3424 View attachment 3425 View attachment 3426 View attachment 3425 View attachment 3426
4 bolt ford racing boss block, bored and stroked to a 331.
4340 forged crank
H-beam rods with arp 2000 rod bolts
2618 pistons with tool grade wrist pins and hellfire rings.
AFR renegade 205 heads with inconel valves.
Scorpion 1.7 intake rocker
1.6 exhaust with girdle bars
custom comp cam
Canton 7 quart oil pan
Custom oil pump
D.S.S windage tray
Custom twin turbo coated hot side
Twin s369 sxe turbocharger
Treadstone 1300hp plus twin turbo air to air intercooler
1500 plus hp built 4l80e with reverse manual valve body and ptc converter. Denny’s driveshaft nitrous 1350 driveshaft
Fully built and braced, welded 8.8 with ford big 9 inch bearings, 31 spline axles, Detroit true trac and 3.55 gears
Big stuff 3 dai/dae with ETM, distributer based 2 step and flex fuel upgrade
Twin turbosmart waste gates and 50mm blowoff valve
Custom cold side piping
15 inch weld rts rears
Stainless steel brake lines
cobra 13 inch front brakes
rear cobra brakes
Team z tubular k-member and a-arms
full strange double adjustable front and rear coil over suspension
adjust rear upper and lower control arms Magnafuel 4303 with Kenne bell boost a pump
Glenn’s performance stealth fuel system with stealth sumped tank
Trick flow track R intake and ported lower with a bbk 75mm throttle body.
evilcw311
Most Evil Member!
Louisville, KY
White either help him out or he. An try editing his original post and using a proper format.
What do you have the pics stored on?? Computer or phone/tablet??
94strokedstang
94strokedstang
None of you pictures worked, boss. Mind if I clean things up a bit for you?
Your help would be appreciated. I pulled the pics off my iPhone. Don’t know what happened. For some resin they would not download.
94strokedstang
94strokedstang
if he isn't a bot, it sounds interesting but I still ain't clicking on anything....
Definitely not a bot. Just another mustang enthusiasts. Waiting on my boost leash/pulse leash controller and we should be able to start her up soon.
94strokedstang
94strokedstang
Stored on my iPhone
evilcw311
Most Evil Member!
Louisville, KY
Stored on my iPhone
You can load them straight to the forum or the easier way is to log into the forum through Tapatalk.
We’re the pics taken on your phone or did you use another device and send them to the iPhone?
94strokedstang
94strokedstang
The pics were taken on my iPhone
94strokedstang
94strokedstang
