boost on stock cams and springs
Pedrothecobra
well im back.... i finally opened up my motor and it was not bad but its not good lol. block is going to a machine shop this week to be checked out, was only planning on re-ringing this motor. but it looks like ill be building this now.
-provided the crank is able to be polished and the questionable cylinder can be bored out, i plan on going with a kit from MMR with all forged internals. i plan on pro-charging later down the road possibly next year provided i get this motor turned around in a decent time frame.
- how much boost/power can i run with stock cams and springs? im new to this game and im still learning. i couldnt find anything on the forums that answered this question.
- can i run stock cams and just beef up the springs? TIA
07GtS197
Fort Myers, Fl
Cams and springs don’t dictate boost. They compliment one another and can limit rpm. How much power do you want to make? With a built bottom end and a blower, even with stock cams, you can make more than enough power for a street car.
P
Pedrothecobra
I’m looking to do a moderate build. Shooting for 600, but the internals I’m going with will be capable of a lot more. I understand cams and springs don’t dictate boost. I’m just trying to find out where the ceiling is on stock heads and the components. Like at what power level will the valves start floating
07GtS197
Fort Myers, Fl
Blak would probably know. I’m not sure what the terminator springs are rated at but seeing that they can handle that power level I’d say anything around that weight spring would suffice. Just don’t go too heavy.
@96blak54
Makoto
Houston
your initial question was the first clue, calling 600hp moderate is the second.
as others have said, springs and cams don't care about power. a spring just needs to close a valve, cams open valves at different times, and so you change these things to change that process. its the lung brain for the engine. that's all. only when valves are closed do the rods, pistons, cranks, blocks, head gasket those things take stress when you start cramming boost in. revving higher than factory is where better springs and cams come into play. the more a valve opens in a given timeframe the more it will need help closing so stiffer springs so cams and RPM determine what springs you need.
that said just cams, springs, and head rebuilds will cost you at least 2K on these engines, probably more like 3K once all is said and done. 4 cams are pricey. you're probably approaching 2K just in parts.
you can run stock cams and beefier springs without issue but it would be pointless.
serious question.... have you ever driven a 600hp car that doesn't have all the modern safety nannies?
P
Pedrothecobra
Yes I have driven high hp cars before. This is my first V8 build and I’m trying to familiarize myself with this modular platform. Appreciate the input, if the car wasn’t a true cobra I’d probably be going a different route with power plant. I know these motors can get pricy when trying to make power
Makoto
Houston
that wasn't what i asked. have you driven a 600hp car without all the safety nannies before? like, not in a parking lot, i mean in traffic and around town, etc.
i'm only asking this because what you're saying isn't adding up.
P
Pedrothecobra
Your question isn’t adding up. What’s a safety nanny? I was asking about stock cams and springs. I guess I can see where my question may have been confusing about what I was trying to find out. I probably shouldn’t have mentioned boost and just asked what the limits of the stock valve train was. I have a habit of typing and sending before clearly thinking about what I’m asking sometimes. Sorry for the confusion I may have caused you
Makoto
Houston
your valve train doesn't give a shit about boost. how about that?
safety nanny is traction control, abs, things like that. the tell is the kind of questions you're asking, that says inexperience, which is fine but also why I think 600hp is a PFA number as opposed to a VC number. Feel free to correct me but I've seen nothing to suggest you have any idea what that even means in a mid 90's fox platform car.
My recommendation: have someone else put your engine together and get it back in the car, do full bolt ons, and have it tuned, throw some gears in and have fun.
lwarrior1016
Mr. Secondary Timing Chain
South Mississippi
The valve train absolutely cares about boost, when you go to high, you will start getting valve float. OP, I’m not sure what the limit is but I know plenty of guys that have gone to 10-12psi and never had an issue.
96blak54
In the shop
If the springs were the old style conical shape...pre-95 and not the newer beehive shape, id say their would be a problem, but these beehive springs in the modulars are amazing.
Snorky
A little late for the party, but you dont really need cams and springs with 4v motors for something like 16-18lbs. Springs are necesary if you get high lift cams, start pushing the higher end of the rpm spectrum OR if you have a turbocharger where back pressure is an issue.
That being said, cams are a great way of making more power at less boost, and moving the power band to a different rpm range
Makoto
Houston
think of how a valve is shaped and how boost would be pushing against it. the springs PULL the valves up, when you pressurize the chamber it will actually help keep those valves up.
as others have said and for the reasons above, valvetrain doesn't care about boost.
the valve train cares about 2 things.
1. oil
2. the ability to close the valve.
This is why the valvetrain only cares about RPM. the higher you go the more you need a stronger spring to bring that valve back up to the cam lobe.
boost in no way hinders the ability to close the valve because every time that chamber fires off that boost is gone then the intake valves open again and more air is crammed into that void, so on and so forth.
This is why I ask people what they have experience with because a lot of guys start throwing parts at builds when they don't understand what is really happening and it either just wastes money or causes issues down the line. That is the difference between really building a well sorted car and just throwing shiny parts at it.
95opal
1. oil
The valve spring is not involved in the valve opening process. Its sole purpose is to close the valve. Higher the boost the higher the spring pressure needs to be in order to keep the valve closed.
96blak54
In the shop
1. oil
(Batting eyes rapidly)
Makoto
Houston
that statement proves you need to reread what i wrote. carefully.
lwarrior1016
South Mississippi
You’re also pushing boost against the back side of the valve when you put boost in to the intake and intake port. You’re not only putting pressure inside the chamber. Go ahead and look up the turbo coyote guys that are having valve float issues on stock engines with boost.
Makoto
Houston
oh my bad i didn't realize he had a coyote. thought it was 4.6 with a totally different valve train.
in that case, the answer is like 800 wheel horsepower with a turbo setup you might wanna start thinking about your valve train.
so i'll add the caveat that IN GENERAL your valve train doesn't give a shit about boost if you aren't running 1 bar and revving out to 7k rpms.
lwarrior1016
South Mississippi
I don’t believe he’s got a coyote, I just know this issue is prevalent in the coyote community and primarily amongst the turbo guys.
By the way, the 4.6, 5.4, and coyote all share the same valve train architecture. The design and function is the same with subtle changes.
Mysticcobra
