complete suspension overhaul help.
Slykin
Tyler, Texas
Just guessin i'm going to say at least $1500 easy all new.. Probably more.
Bilstein shocks/struts - 550-600?
MM Adj. lca's - 380
steeda bumper steer kit - 100? Not including bumpsteer gauge.
CC plates - 180
Sport springs - 300ish? Not sure on this one really.
Urethane bushings <100 I hope.
Rough Estimate.
Brian95SVT
Chesapeake, VA
Not to have this taken in the wrong way but Jason probably didn't buy them all brand new which is why I asked. He's good at "wheelin and dealin"
twovalveterror
Dayton, Ohio
I have never seen mm denounce tokico, but they dont suggest them for people who plan to go coil overs becuase tokicos cannot be used for that. your ideas look good, I can only suggest not to cheap out on parts. buy the right stuff the first time. mm is an awesome manufacturer for suspension components. also, do not get upper control arms if you plan to autocross the car, any aftermarket upper (that I have seen) is designed for drag racing only. if you plan to keep the car long and want to do drag and auto cross you should look into a torque arm panhard bar/ watts link combo and start building in that direction.
but before you buy any parts, get some seat time at the track!
vermilion
maryland
traded UPR LCAs and 75 for MM adj LCA.
corral'd C/C plates. 105$
steeda bumpsteer new from stangsuspension before they closed originally.
craiglist 70 for sport springs.
Bilstein shocks for 150 and working on getting new struts.
urethane bushings when the stockers tapped out. only urethane or rubber bushings i have now is in the LCAs.
i wheel and deal. i dont know what ive spent but its a lot less then what out of the box youd buy. ive had this jalopy since 2007 and yearly i find deals. i ditch and swap parts monthly. im on a military budget.
Superman3872
