Dead battery after replacing cig lighter fuse
07GtS197
Fort Myers, Fl
Could still be a failing alt. I had one go on my gray 02 years ago. It would start fine after sitting and randomly stop charging and die.
MSTCBRA
MSTCBRA
Elgin, IL
Just starting to feel confident to take it out again and you post this reply? Thanks, it’s at the forefront of my mind.
Adfalenski
Pasquotank county, NC
Pull out the Bluetooth adapter when the car is not running and see how long your battery lasts. If it still discharges, it is something else. What else goes through the unswitched(always hot) circuits?
pretty sure the mach amp in the dash does
Bronco2Fan
Texas
Is this the Mystic that was for sale for ever on the SVT Forum? Guy was from Illinois too, I think, Just curious.
MSTCBRA
MSTCBRA
Elgin, IL
Yes I did this experiment for a week now. Haven’t started it since last Saturday and checked voltage everyday. The battery started around 12.5 and is now at 12.
MSTCBRA
MSTCBRA
Elgin, IL
No. I think that one you’re thinking of was a highly modified one from Joliet area. This one lived most of its life in Arkansas.
MSTCBRA
MSTCBRA
Elgin, IL
half a volt over a week will slowly kill a battery. look under the radio for the mach amp and disconnect it
Yes but it’s better than completely dead after 10 days. Progress! Today is a test drive to make sure the alternator charges at all speeds.
MSTCBRA
MSTCBRA
Elgin, IL
I took it on a 40 minute drive yesterday at a variety of speeds. No issues. Voltage gauge looked good. It was on the R the whole time and only moved down between O and R for a few minutes. Came back and it was high 13s when running and 12.7 when off. I think I’m good!
MSTCBRA
MSTCBRA
Elgin, IL
As Vice Grip says “I’ve got updates”. All last season I’d disconnect the battery after driving it because there’s some drain happening while sitting. The alternator would charge properly over the 2,000 miles I put on it. Today I started it for the first time since November and the alternator doesn’t seem to be charging the battery. At idle the battery is at 11.76 volts and the voltage gauge is at the N while driving. No batt light on. Is it time to replace the alternator?
at the very least you can either take it off and have it tested or it isn't as good but still works, vatozone can hook up to it in the car and say if it looks good/bad
cobrajeff96
Germany
What happens off-idle though? Do you give it a bit of juice and hold for a few seconds? Or is it always just idling?
Not sure your exact setup but factory alternators of this era are notoriously weak at idle. They may be rated for x number of amps but that number fluctuates in the rpm range. And it also depends on the regulator and in the modern era the ECU itself. If I were you I'd take it for at least a 5 min drive, ideally longer. Might change things.
MSTCBRA
MSTCBRA
Elgin, IL
I drove it to get gas. Noticed the volt gauge was lower than it was last year when I knew it was charging. So I got gas and came back home to put a meter on it. I’ll pull it off and have Oreillys test the alternator.
