Diff question... compatibility?
Monday
If I were to gut a 2005 rear end, would it install into my 96 rear axle? I believe they have 31 splines.
My diff is leaking from the wheel - seal might be gone; don't know, as I had someone else install the 410s.
Any help is always appreciated. Thank-you...
lwarrior1016
Mr. Secondary Timing Chain
South Mississippi
The diff carrier should swap over no problem. I don’t believe the axles will work due to length differences. You’ll have to get 31 spline axles for your housing.
Monday
Monday
Thanks for your wisdom members. I appreciate you...
badass98svt
My 98 has a 2007 GT500 differential in it. The gears/diff should be good to go. Only real difference I know of is the diff cover is more shallow on the s197 (to clear the panhard bar maybe?)
I can't comment on the axles, but I doubt they work.
FHCee
