Do I need the air tube?
Ahgrafx
Auburn, WA
So I'm under the car replacing my stock hpipe/cats with an off road hpipe and I see that when the previous owner rebuilt the engine he just plugged the tube. Can I just delete the tube and close it off at the hpipe? I see is has this filter thing at the end do I need that?
Sent from my HD1905 using Tapatalk
07GtS197
Fort Myers, Fl
Thats actually a check valve. You could remove the crossover and install air delete bolts in the back of the heads. You don’t need to run any of that air pump stuff.
A
Ahgrafx
Auburn, WA
If it's been running like this I'm sure they already installed the bolts in the back of the heads right? What's the purpose of the check valve?
RAU03MACH
NEW MEXICO
Do you have emissions tests
That would be the only down fall
I did a complete delete on mine
But I have no emissions tests
Werecow
Virginia
Go ahead and gank it, as long as you don't tell the greenies you'll be safe...
Superman3872
