fuse charts for 1994 GT 5.0 5 speed convertible
1994Gtmustang
Thats why i said put 12v to that fuse. Quickest way to verify bad power source.
Good idea so you said take out the fuse and run 12 V to it at that point I should see power at the plug by the coolant temperature switch, correct
This is not a bad idea but I would recommend putting a fuse on that jumper wire. This can be done easily if you have crimp on female spade connectors if you have them(doesn't everyone?).
1994Gtmustang
I will keep everyone posted when I get home today. If this works, then there’s a bad connection under the actual fuse box.
1994Gtmustang
I’ve traced everything down, tested every wire every circuit. Everything leads back to the PCM. I will wire up an external switch for the fan very easy, it is not my daily driver so I will just have to monitor the temperature. It seems that this is the problem with these N95 mustangs
Nemec
