Guess and win
Randy
Thought I would have some fun at my expense. I have my 95 Mustang GTS.. Stock bottom 302 ( EDIT- E 303 cam).. at the shop to get a tune and some repairs. They are putting in new hardened push rods and chromyl rockers and then testing for vacuum leaks and dyno tuning it.. I just bought the car on Sept 3 -13 .. Dyno will be done on motor only no adders ...Closest Guess will win $25.00 ... (Must have pay pal to receive gift) .. Tune should be done on Friday 12-13... as long as parts are in.. But if not tuned by Friday 12-20 closest # to 0 wins.' 1 guess per( MEMBER) with at least 50 post's guesses are due by 12-11 at midnight... Who- ever guesses on the money gets a extra 10 $ .. Rear wheel hp . in case of a tie we will get into torqe at 4200 rpm.. Good luck
373 rear end
31 spline axles
weld on sub frame connecters
alum drive shaft
tk5 tranny--- short throw 5 speed
Trick flow track heat upper and lower and heads 1 in intake spacer
75 mil throttle body
24 lb injectors
bbk cold air intake prow flow maf
3 core alum radiator
egr delete smog delete
under drive pulleys
MSD billet Dizzy -coil -ignition
9 mil plug wires
pistons are stock
May the best guesser win ..
Not sure on fuel pump but I have inline and external.. Like I said just bought car..
Devin72
