help with replacing suspension parts
mppaintball
so im about to replace the parts in my drivers side front suspension since i cant stop the damn squeaking form the bushings. Ive never done this before so can someone walk me though it, and any special tools i may require. Thanks
duff daddy
sure its pretty easy... lest start at square one...
what are you replacing???
mppaintball
well im trying to stop this very annoying sqeak in the drivers side, which i think is the bushings, but im not positive. So i found a used set of springs, shocks, struts for the drivers side for $60 (is that an ok price?) so i would probably replace those. Also would that stop the squeak or do you guys think it is something else?
duff daddy
it could be a ball joint thats noisy, it could be tie rod end thats noisy, could be a sway bar bushing thts noisy or sway bar link... its hard to say
mppaintball
well it squeaked when i got it a little over a year ago, but stopped in the rainy season and now that it is warm again it is squeaky again. it does it when i push on the front drivers side fender, and it does it when im driving like under 30. I can hear it with every single little bump. it also squeaks sometimes when i turn the steering wheel.
mppaintball
can i replace just the ball joint without talking apart the entire suspension for that side?
peasant99
