Highlighted posts from Friday, Dec. 10, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
December 09, 2021 * 14 posts * 50 views
jonathan2000gt said: i bought a 09 crown vic motor to put in my mustang dipstick snapped off and now cant get it how tried drilling it but at the angle cant get it dont know what to do Read more >>
December 09, 2021 * 13 posts * 54 views
RAU03MACH said: just a question is that a 2 valve if so i will be changing mine over to a 4 valve and i wont need the 2v cover but just keep in mind it will be a bit, i still need to get a few ... Read more >>
December 09, 2021 * 11 posts * 115 views
Chip66 said: The best lobe separation angle is a product of displacement, compression ratio, and intake valve size. The best LSA has nothing to do with duration or lift. If you go too big on ... Read more >>
December 09, 2021 * 12 posts * 76 views
Jason.Silus said: I assume you're talking about the mass airflow sensor? It works just fine, I've tested it while it's running and when it dies. Read more >>
December 09, 2021 * 2 posts * 26 views
70RustBucketList said: Hi all, Was just wondering if there was a rear differential gear ratio calculator somewhere, or if there was a post with an RPM reference for auto and 5 apeed trans when you swap ... Read more >>
December 09, 2021 * 1 post * 19 views
94StewFord said: Gathering parts for a Spring Tune-Up. I am looking at the Champion Copper Plus plugs as they are a bit hotter, vs the Motorcraft 450's. Also, are the factory wires ok? My car only ... Read more >>
December 09, 2021 * 1 post * 7 views
SN95Newsletter said: Click here to view on the web Highlighted posts Supercharger compression ratio December 08, 2021 * 51 posts * 352 views 94-95 5.0 - Specific PATS system December 08, 2021 * 18 ... Read more >>
December 09, 2021 * 12 posts * 198 views
BOTTLEFED5 said: Thanks! video was on 17ish lbs, I shift it at 7700-8k depending on whats going on. Read more >>
December 09, 2021 * 22 posts * 925 views
Micmac1 said: lol Yeah I'm not super impressed with that. it is what it is though. it did fit right in, on my 1995. I had to swap the clutch fork to a fox body fork other than that it was pretty ... Read more >>
Continue reading...
rlmobile636
