Highlighted posts from Friday, Feb. 04, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
February 03, 2022 * 17 posts * 211 views
myk said: Just an update, I pulled, reattached and examined all electrical connections, plugs, harnesses, etc, just to see if a difference in idle quality could be found. I dug into the ... Read more >>
February 03, 2022 * 5 posts * 35 views
07GtS197 said: I've run Valvoline Mercon in two 3650s and a t45. Never had any issues cold or hot. I know the 3650 can be picky when it comes to fluid but that hasn't been my experience. Read more >>
February 03, 2022 * 8 posts * 69 views
joemomma said: True story. My best friend who is a Mustang guy (although mostly classics) had no idea my car had the 302 in it when I got it. Read more >>
February 04, 2022 * 2 posts * 11 views
Jason.Silus said: As I understand it to be, the connections for the gauge clusters are specific to years 94-95, 96-98, and 99-04. I have a '96 GT, with the fuel gauge needle not moving. I've tested ... Read more >>
February 03, 2022 * 1 post * 9 views
SN95Newsletter said: Click here to view on the web Highlighted posts Water leak in my 96 February 03, 2022 * 16 posts * 109 views Exterior and Interior Confused about the PATS system February 02, 2022 ... Read more >>
February 03, 2022 * 37 posts * 630 views
J_lope82 said: I have a corsa exhaust on my truck. Sound system with double din, upgraded speakers and sub box. I have some cool mods on it that makes me enjoy driving it and I can still haul ... Read more >>
February 04, 2022 * 4 posts * 54 views
Flade said: I have 4 SN95 Mustangs with the Mach 460. I have never had to replace a speaker. Only the Amps fail. Read more >>
February 04, 2022 * 16 posts * 266 views
1998MustangVert said: I was able to use FORscan and that cable to erase and reprogram the PATS keys. My hunch was right, there was an additional key somewhere that was programmed to my car, but no more! ... Read more >>
February 03, 2022 * 6 posts * 709 views
brandon__203 said: What wires did you end up needing out of the ccrm. The right corner and just the trans Read more >>
Continue reading...
RevJon
