Highlighted posts from Friday, May. 07, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
May 06, 2021 * 9 posts * 117 views
96blak54 said: Youd be surprised some of the janky conditions that run in an engine. Read more >>
May 06, 2021 * 6 posts * 98 views
TrickVert said: You're doing almost exactly what I did on my '95 in 2008. I kept the stock MC at the time. The pedal with the stock one was firmer than with the OEM brakes, but still very manageable. ... Read more >>
May 06, 2021 * 3 posts * 60 views
9838stang said: On my car, I have J&M upper and lower control arms, J&M upper spherical axle bushings, ad the lower control arm has spherical bushings as well. But the body had the poly bushings. ... Read more >>
May 06, 2021 * 13 posts * 274 views
Blueraz_5.0 said: Exactly, I need to be able to daily it without hating myself. Read more >>
May 06, 2021 * 4 posts * 71 views
Blueraz_5.0 said: This actually might be just what I've been looking for with some of the interior lighting and maybe the tails :) thanks! Read more >>
May 07, 2021 * 2 posts * 59 views
sluggish94 said: You'll be fine with those valve springs if you're keeping the stock cam. Why? Stock cam only has about .444 lift, and even if you upgrade to some 1.7 rockers, it will still only ... Read more >>
May 07, 2021 * 1 post * 7 views
SN95Newsletter said: Click here to view on the web Highlighted posts Flywheel during clutch replacement May 06, 2021 * 15 posts * 308 views 96-04 - 2V Specific 94 GT Cobra brake upgrade about to start... ... Read more >>
May 07, 2021 * 2 posts * 74 views
Daryl said: New member Scores8 chimed in. Looks like we may have a deal, but..... Anybody else? Read more >>
May 06, 2021 * 28 posts * 514 views
Rich said: Doing a quick hijacking of this thread... I've been meaning to ask you guys about a shaking I get if I'm in say 4th gear and slow down to 10 mph but don't down shift. The whole ... Read more >>
May 07, 2021 * 2 posts * 58 views
Daryl said: Nope. That's pretty much your only option, unfortunately. Just make sure the O2 sensor is pointing upward as much as possible and as close to the collector tube as possible. Read more >>
Continue reading...
Suprasuavy
