Highlighted posts from Friday, May. 21, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
May 20, 2021 * 21 posts * 244 views
Daryl said: DkBlue, I'm the opposite! Up front,K-member's no issue. Out back... I've had a couple of light scrapes: one steep driveway and a rock in the road. Looked small enough to go over, ... Read more >>
May 21, 2021 * 13 posts * 130 views
TrickVert said: Both the Jeep and the TLX have their batteries under the hood, and both (the V6 Acura, mine's an I4) specify AGM batteries. The AGM batteries are called out mainly because of the ... Read more >>
May 21, 2021 * 4 posts * 30 views
5OMustang said: Hey everyone, I have a 94 GT 5.0 5 speed with 190 twisted wedge heads, trickflow cam, 30lbs injectors, 75mm throttlebody, longtubes, custom tune with a systemax. Engine was rebuilt ... Read more >>
May 20, 2021 * 1 post * 30 views
Burninrock24 said: Has anybody vinyl wrapped their entire car? I'm going on my 3rd body panel with a different shade of black and it's starting to look like a patchwork quilt under direct sunlight. ... Read more >>
May 20, 2021 * 1 post * 24 views
Chenn2389 said: Has anyone attempted the TKX swap yet? Is it a direct swap? I have a feeling the fresh built 3.35 close ratio T5 is gonna suck with 3.73s out back and my new stroker. First gear ... Read more >>
May 20, 2021 * 1 post * 4 views
SN95Newsletter said: Click here to view on the web Highlighted posts Alternative to Eibach rear sway bar? May 20, 2021 * 15 posts * 165 views 94-95 5.0 - Specific Battery selection... May 19, 2021 ... Read more >>
May 20, 2021 * 11 posts * 459 views
PinkieT said: Murphy's Law kicked in. The differential my buddy gave me is good, but I have 28 spline axles and it takes 31. Trip to Summit, more $$$$ out the window.... Read more >>
May 20, 2021 * 11 posts * 467 views
Chenn2389 said: Crane designed the cobra 1.7s specifically for Ford. They were made to fit the stamped steel covers on the cobra. Only difference in the cobra covers is they have a lead liner ... Read more >>
Continue reading...
ArcAngel
