Highlighted posts from Friday, Sep. 09, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
September 08, 2022 * 61 posts * 706 views
That Mustang Guy said: That I already know and am glad we just recently went to court with the EPA and had a small victory. But we still need more people to make their voices heard with the rest of us. Read more >>
September 08, 2022 * 15 posts * 55 views
dwcopple said: So popped a code today, P1740. Supposedly a TSS shorted open. Confirmed by shifting auto shifter to "2" and car immediately stalls. How big of a PITA is this gonna be? Anyone ever ... Read more >>
September 09, 2022 * 6 posts * 46 views
ttocs said: My bassani off road pipes had some tabs but it wasn't something that just wanted to bolt right up. That might also because the T56 magnum in it is a little bit bigger but a good ... Read more >>
September 08, 2022 * 10 posts * 131 views
Thyme said: Yep, exactly how it works. The 23 tooth speedo gear that would go in my car to correct my gear ratio seems to enjoy exploding itself, which turned me onto this device. Using a ... Read more >>
September 09, 2022 * 1 post * 13 views
Pedrothecobra said: Im finally getting my motor back in my car and ran into an issue with my secondary air pump piping. the fitting on my passenger side has stripped both the fitting and nut. im currently ... Read more >>
September 08, 2022 * 1 post * 9 views
RacerX said: I have this Ford Racing 8.8 Diff Cover. [image] Going to change the fluid out and looking at the instructions that it came with doesn't have any torque specs for the drain or fill ... Read more >>
September 08, 2022 * 1 post * 8 views
SN95Newsletter said: Click here to view on the web Highlighted posts Can i... September 07, 2022 * 55 posts * 600 views General Tech Unknown engine setup, svo 4v? September 07, 2022 * 4 posts * 26 ... Read more >>
September 09, 2022 * 44 posts * 515 views
Oakway9092 said: Alright so I did a bit of monkeying around on the car: Without any switches jumped: the reading was at 56psi With both hi and low switches jumped: it dropped a bit more to 52psi ... Read more >>
Continue reading...
