SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 547
- Reaction score
- 0
Click here to view on the web
Highlighted posts
April 03, 2022 * 19 posts * 198 views
Exhausts
TrickVert said: You're over-thinking this. Unless you choke the living heck out of something, the sound will not differ much with or without the O/R H-pipe. Yes, it would be a little bit louder, ... Read more >>
April 03, 2022 * 15 posts * 145 views
04RedfireGT said: Alright thanks for the info, I'll check the vacuum lines. I was gonna go get a loaner tool from the parts store as well to check fuel pressure. However at idle the car runs fine ... Read more >>
April 03, 2022 * 1 post * 11 views
SN95Newsletter said: Click here to view on the web Highlighted posts Exhaust set up help! April 03, 2022 * 16 posts * 156 views Exhausts 00' 3.8 EGR Delete w/o tune ?help? April 02, 2022 * 8 posts ... Read more >>
April 04, 2022 * 54 posts * 435 views
JIMRSX said: I had the exact, I mean exact problem with turn signal fuses blowing on my 94 Cobra. Turned out a wire harness and wire has rubbed through and was shorting to bare steel. Directly ... Read more >>
April 03, 2022 * 14 posts * 303 views
Duff said: I installed new insulators and also the factory rubber sleeves that fits inside the coils, maybe they're a damper? If I would've had help, I wouldn't needed a spring compressor, ... Read more >>
Continue reading...
