Highlighted posts from Sunday, Aug. 28, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
August 27, 2022 * 17 posts * 120 views
BHernandez said: It's hard to tell with folks like that. We look at it from performance or appearance point of view and think "Well it's just $0.25 or even $1.00. But when they look at something, ... Read more >>
August 27, 2022 * 60 posts * 337 views
ttocs said: start at fuse 35 in the diagram and follow the line down. See where the green line splits off to the right labeled "Shift interlock/abs/bla bla bla" and the S272 next to it? That ... Read more >>
August 27, 2022 * 26 posts * 322 views
cobrajeff96 said: Could be just burrs from factory casting flash just flaking off. If that was all the shavings there was (in that pic of the oil pan) that's really nothing to worry about. It's ... Read more >>
August 27, 2022 * 9 posts * 146 views
Rod said: Something to remember with replacing parts is NEW stands for Never-Ever-Worked. Test all parts, if there is a way, whether old or new before replacing/installing. Something else ... Read more >>
August 27, 2022 * 7 posts * 159 views
Rod said: IDK. There is a lot of things on the interwebs that say never clean just replace if testing is out of range....BS. Just don't be stupid about it. Read more >>
August 27, 2022 * 11 posts * 177 views
03torchgt said: Hey I really appreciate that! I actually found a guy who is local who will be taking care of everything for me though. I also pulled the trigger on a motor/trans out of a 2019 ... Read more >>
August 28, 2022 * 1 post * 6 views
SN95Newsletter said: Click here to view on the web Highlighted posts Why did the tire size change from 255/45 to 245/45... August 26, 2022 * 10 posts * 59 views General Tech Cruise control problem ... Read more >>
August 27, 2022 * 16 posts * 362 views
Cochise said: This is the first time I've heard this. The current tuning set up is just a stop gap until I get everything saved up for my Coyote swap. To be honest I'm already regretting the ... Read more >>
August 27, 2022 * 5 posts * 167 views
Rod said: Like the other replies bad grounds are BAD and can cause any kind of bad thing to happen, including what you have experienced. Read more >>
August 27, 2022 * 14 posts * 313 views
Rod said: This is a reach, but you said you have 4:10 gearing right? Did the speed snesor gear get changed when the gears did? That shouldn't effect idle but would drivability, and the 'learning ... Read more >>
Continue reading...
Srchop16
