Highlighted posts from Sunday, Feb. 13, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
February 12, 2022 * 20 posts * 159 views
Snorky said: Having had a centri on my car and a turbo kit. The turbo kit will annihilate the centei blower in terms of power, but it comes with a severe cost. I find that the turbo set has ... Read more >>
February 12, 2022 * 15 posts * 122 views
tinnocker said: rickVert said:Back in the 60's/70's,this may have been true, but today fuel is filtered at the refinery as it goes into the truck, again when it flows out of the truck into the ... Read more >>
February 12, 2022 * 12 posts * 154 views
ttocs said: not for something small like that. I would go to ebay if your looking for easy. Read more >>
February 12, 2022 * 6 posts * 31 views
J_lope82 said: Guys looking for tips/advice on how to install 3" arp wheel studs on new rear axle shafts. I just ordered two new drill bits to drill out the holes. I ordered a 37/64 and a 39/64. ... Read more >>
February 12, 2022 * 24 posts * 215 views
Darkfiggy said: And this is why I replaced those compression ones with the tab slot ones when I swapped out my headlights. I usually put the end that goes through the subframe with the slot horizontal ... Read more >>
February 12, 2022 * 5 posts * 33 views
Booboo said: 1997 Mustang 4.6l - There is a hole with a grommet on the passenger side valve cover. Is there something that should go in this hole? [image] Read more >>
February 12, 2022 * 5 posts * 29 views
Daryl said: I can't seem to find an exact replacement for my trunk's "SVT Cobra" badge. I found just the "SVT" from another year, but it's smaller and doesn't have the "Cobra" lower portion. ... Read more >>
February 13, 2022 * 1 post * 6 views
SN95Newsletter said: Click here to view on the web Highlighted posts Turbo or Supercharger? February 11, 2022 * 11 posts * 70 views 96-04 - 2V Specific Removing Headlights/Clip Won't Budge! February ... Read more >>
February 12, 2022 * 131 posts * 1,277 views
Pedrothecobra said: So as to the fuel pressure dropping and the car breaking up. The problem has cleared up with a new 255 pump. Idk if the pump I replaced was bad or just could t keep up. But the ... Read more >>
Continue reading...
RevJon
