SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 547
- Reaction score
- 0
Click here to view on the web
Highlighted posts
July 09, 2022 * 9 posts * 51 views
cobrajeff96 said: Keep in mind that a slight preload on the pressure plate (even with the firewall screw close to the firewall) is not only fine but desirable. There should be no air gap between ... Read more >>
July 09, 2022 * 18 posts * 144 views
SN95_Project said: They must have cut them out then. Looks like I need to find a wiring diagram and see if they just cut the wires flush with the harness. It's probably not worth the hassle at this ... Read more >>
July 09, 2022 * 1 post * 22 views
tinnocker said: I have never taken the 95 stalk off but some just have a couple of small screws holding the flat end to the signal switch. If that is the way it is made it would be easy to put ... Read more >>
July 09, 2022 * 14 posts * 109 views
TrickVert said: I was concerned about that, too, and did the same thing. These are very even, and the lights are now ruby red instead of having an orange-ish cast. (I did retain the standard reverse ... Read more >>
July 09, 2022 * 2 posts * 3 views
SN95Newsletter said: Click here to view on the web Highlighted posts Clutch Cable Question July 08, 2022 * 2 posts * 15 views Drivetrain Turn Signal Stalk - Too Low July 08, 2022 * 1 post * 12 views ... Read more >>
July 10, 2022 * 2 posts * 8 views
Daryl said: I have the thin style door lock knobs (so not actually knobs then, right?!). Driver side would not actuate via fob or door switch. Passenger side started working again, but I can't ... Read more >>
July 09, 2022 * 7 posts * 239 views
NicksGTR said: Update. My 30k Mustang Bullitt (2001) finally back on the road. My 1-2 shift grind is GONE! Change the fluid from factory fill, probably Mobil 1, to GM Synchromesh. Night and Day ... Read more >>
Continue reading...
