Highlighted posts from Sunday, Jun. 19, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
June 18, 2022 * 15 posts * 136 views
dcm0123 said: Power train control module also known as Constant Control Relay Module CCRM? $50 through RA but quality unknown It is on the bracket which supports the radiator overflow tank. ... Read more >>
June 19, 2022 * 6 posts * 24 views
Booboo said: The 8.8 rear end in my 1997 GT is making grinding noises. The plan is to rebuild it with 3.73 gears. I am wondering if I should replace the axles or differential too. The plan ... Read more >>
June 18, 2022 * 3 posts * 18 views
Boostr1 said: @lwarrior1016, Is this fixture ok to hold the trans at 90 degrees? Or should I have something to support the weight to assist this. [image] Read more >>
June 18, 2022 * 3 posts * 38 views
cobrajeff96 said: Bought stuff from them before a few times, good seller. Read more >>
June 18, 2022 * 1 post * 22 views
cobrajeff96 said: Dual Gasoline O2 sensor system from FAST, never used even once. I had plans to make use of it eventually but those plans never happened. $500.00 shipped anywhere in the lower 48 ... Read more >>
June 18, 2022 * 1 post * 17 views
cobrajeff96 said: Got a black powdercoated billet power steering reservoir cap for any 96-04 (and possibly other years, IDK) with an engraved red SVT logo. Reuse existing gasket. $50.00 shipped ... Read more >>
June 18, 2022 * 1 post * 14 views
cobrajeff96 said: Professionally-chromed by Spacecoast Plating, FL some years ago and has been sitting in my basement ever since I did a Coyote swap in the '96. As you can see, these are quite clean. ... Read more >>
June 19, 2022 * 1 post * 6 views
SN95Newsletter said: Click here to view on the web Highlighted posts When hot it sputters & dies, wait, starts and runs great, repeat June 17, 2022 * 12 posts * 93 views 94-95 5.0 - Specific Squeal ... Read more >>
June 18, 2022 * 23 posts * 461 views
cobrajeff96 said: Doesn't the speed signal get used by ECU to keep the engine alive despite zero throttle input (TPS)? I know in the later model engines (Coyote) they call it "Torque Decel" and ... Read more >>
Continue reading...
rlmobile636
