Highlighted posts from Thursday, Jan. 27, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
January 26, 2022 * 63 posts * 403 views
Pedrothecobra said: [image] ok so UPDATE: im pretty sure this Schematic is wrong, the fuel pump relay is showing normally open. the relay in the car is a normally closed. that aside i took a voltage ... Read more >>
January 26, 2022 * 8 posts * 56 views
joemomma said: Yeah the dynomat stuff is just going to cut down on heat/noise/vibration through the hood, it is supposed to help protect the paint from engine but but I don't know. It would likely ... Read more >>
January 27, 2022 * 26 posts * 344 views
Gregomatic said: Cool, I'm interested in seeing the pic too. Hey, nice to see ya posting again Niner Fife! Read more >>
January 26, 2022 * 1 post * 12 views
SN95Newsletter said: Click here to view on the web Highlighted posts 96 cobra breaks up under WOT January 25, 2022 * 48 posts * 337 views General Tech Anyone use Jenkins Tuning Innovations? January ... Read more >>
January 27, 2022 * 1 post * 6 views
abood89 said: Hello everyone! Looking for 94-98 Black "not charcoal" cobra driver side airbag. If anyone has one in excellent condition for sale, please PM me. Thanks in advance! Read more >>
January 26, 2022 * 21 posts * 379 views
Buffalo5Spd said: MAF weirdness will almost always go away under full throttle. MAF is used for part throttle metering. I learned this when I had a MAF come loose on a car when the clamps weren't ... Read more >>
January 26, 2022 * 7 posts * 101 views
Chip66 said: I too agree with this philosophy. If you want to rely on these older cars, preventative maintenance is a must. I wouldn't hesitate to take my '94 across the country tomorrow. In ... Read more >>
January 26, 2022 * 34 posts * 439 views
95opal said: Dont matter KOEO if a code was tripped its tripped. I just wanted to make sure you cleared the codes after the vac leak repair. Once you verify vacuum at the egr i would start ... Read more >>
Continue reading...
Superman3872
