SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 547
- Reaction score
- 0
Click here to view on the web
Highlighted posts
May 11, 2022 * 22 posts * 234 views
gcassidy said: Pics of them. One bushing is still in the plate. Read more >>
May 11, 2022 * 17 posts * 172 views
ttocs said: either or no matter what M&M makes the absolute best gear and there is no substitute. Ok wow I think cobraracers brain washing might have just gone by. two drinks Read more >>
May 11, 2022 * 6 posts * 48 views
Venompower said: The last three things I need to address to get the car solid are: 1. Suspension 2. Clutch Engagement 3. Air Conditioning / Radio The biggest issue with enjoying driving the car ... Read more >>
May 11, 2022 * 5 posts * 71 views
Adfalenski said: The only difference is a removable plastic block on the door near the latch. I removed the block and replaced it with the screws located in the same place from the old door. Read more >>
May 12, 2022 * 4 posts * 22 views
SouthernGorilla said: I'm about to put new brakes all around because mine are grinding. They are also a bit questionable when dropping out of warp speed. My only hold-up right now is that I can't cut ... Read more >>
May 12, 2022 * 2 posts * 16 views
MJN said: Hello Everybody. I know that this has been done to death but I am at my wits end with this and since I am having an intermittent issue tracing it has been a bear. the symptoms ... Read more >>
May 11, 2022 * 3 posts * 40 views
badass98svt said: FRPP Gears SFC (MGW) Shifter Those would be my first 3 mods if it is all stock. Assuming yours is a 5 speed. Read more >>
May 11, 2022 * 1 post * 8 views
SN95Newsletter said: Click here to view on the web Highlighted posts Kenny Brown caster plus CC plates May 10, 2022 * 20 posts * 198 views Suspension and Brakes Low Coolant idiot light May 10, 2022 ... Read more >>
Continue reading...
