Highlighted posts from Tuesday, Dec. 07, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
December 06, 2021 * 33 posts * 158 views
tvsn95 said: You SHOULD be no more than 9:1. thats a lot of boost for the combo you are thinking about. you WILL need way more fuel system. 60lb are fine up to 750hp but you should probably ... Read more >>
December 07, 2021 * 5 posts * 48 views
wvmedic99 said: So, I think it is a coupler, but the rag joint is definitely in the engine compartment right above the steering rack input shaft. What we did to fix this issue was drilled out ... Read more >>
December 06, 2021 * 7 posts * 29 views
ttocs said: well yes that is impossible because what they are describing is the VATS sytsem that gm uses with a resistor in the key. PATS uses a passive transponder that repeats/reflects and ... Read more >>
December 06, 2021 * 9 posts * 92 views
tvsn95 said: So for my education ,, WILL a 98 return styie basket tank fit into the 94-95 without any mods other than fuel lines? I have built several cars and the fuel systems are a pain, ... Read more >>
December 06, 2021 * 3 posts * 24 views
Falconman said: I just bought an '02 3.8. The car is from Maryland. The entire exhaust system is rusted due to the salt on the road during winter. I'd like to convert to duals. Is there a ready-made ... Read more >>
December 06, 2021 * 1 post * 6 views
SN95Newsletter said: Click here to view on the web Highlighted posts Supercharger compression ratio December 04, 2021 * 12 posts * 78 views 94-95 5.0 - Specific Pats key reprogramming December 03, ... Read more >>
December 06, 2021 * 12 posts * 324 views
ttocs said: its all about where you drill the hole. IF he had only gone up a few inches in the black area the gauge shroud is easily replaced. Read more >>
Continue reading...
RevJon
