Highlighted posts from Tuesday, May. 17, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
May 16, 2022 * 22 posts * 197 views
tinnocker said: What does yours idle with the b-cam. I have been dealing with everything you are talking about on my 94 GT with aluminum heads, comp cam, and gt40 ported upper and lower manifold. ... Read more >>
May 17, 2022 * 22 posts * 293 views
Warhorse Racing said: When it comes to coil-overs, quality is really important. An inexpensive kit might not provide the results you are looking for. LMR sells a "stock replacement" front control arm ... Read more >>
May 16, 2022 * 6 posts * 25 views
Booboo said: 1997 GT turn signal problems. I replaced all of the bulbs, 6 in the back and 2 up front, I've swapped the bulbs around and they all are good. The inner bulbs on both sides in the ... Read more >>
May 16, 2022 * 1 post * 6 views
SN95Newsletter said: Click here to view on the web Highlighted posts Idling issues and in need of some help! May 16, 2022 * 16 posts * 105 views 94-95 5.0 - Specific Budget Suspension Upgrade? - (Team ... Read more >>
May 16, 2022 * 17 posts * 309 views
oilspill said: Turns out these were WRONG, i should have checked them! I have contacted the company and waiting to hear back if they will make this right. Until then no ABS which is not the end ... Read more >>
May 16, 2022 * 15 posts * 786 views
tvsn95 said: for what its worth the TPS has NO connection to the described problem. TPS serves to let the ECU know that the throttle is at idle and give accelerator shot info to the ECU. slight ... Read more >>
Continue reading...
peasant99
