Highlighted posts from Wednesday, Mar. 30, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
March 30, 2022 * 12 posts * 158 views
NEURON said: Which Performance Kits are you talking about specifically, that is a pretty broad term. Read more >>
March 29, 2022 * 17 posts * 222 views
CobraRGuy said: Something you should check is the recommended float voltage of the battery and float voltage the trickle charger is using. The manufacturers of both should be able to give you ... Read more >>
March 30, 2022 * 5 posts * 15 views
KasperBPMC said: Hello All, so my thought is this. Electronics have come along way since my car was new. Has anyone gutted the 460 system and replaced it with components with passive crossovers? ... Read more >>
March 29, 2022 * 4 posts * 30 views
04RedfireGT said: Alright so I have a 2004 Mustang GT with 248k miles. I've had it since February of last year with no issues. No leaks or anything and all of the sudden it started dying whenever ... Read more >>
March 29, 2022 * 13 posts * 79 views
ttocs said: ok that is what I thought you were talking about, now I just have no idea why? If you thought I that is what I meant when I said the one touch relay was bad that is an actual relay ... Read more >>
March 29, 2022 * 5 posts * 55 views
winged.racer7 said: Seeing that there are lowering sping kits for your car from various suppliers I would hazard a guess that the springs are all the same diameter but just a different length and ... Read more >>
March 29, 2022 * 11 posts * 205 views
Daryl said: Nitto 555 RII Drag radials in back, size 305/45x17. Nitto 555 GII's up front, size 275/40x17. BANG!! Read more >>
March 29, 2022 * 5 posts * 95 views
KasperBPMC said: I am by no way a car audio installer, i am an electrical engineer by trade. I found every answer to these electrical issues i had by going to The12volt.com They got a full remote ... Read more >>
March 29, 2022 * 1 post * 11 views
SouthernGorilla said: Is there a code somewhere to tell me what color top came on my convertible? There are a couple sketchy spots, so I'm looking at replacing the top in the near future. The current ... Read more >>
March 29, 2022 * 1 post * 9 views
SN95Newsletter said: Click here to view on the web Highlighted posts Brake Kit or Originals March 28, 2022 * 11 posts * 101 views 96-04 - 2V Specific Engine swap planning - analysis paralysis March ... Read more >>
Continue reading...
JohnnyOctane
