Highlighted posts from Wednesday, Oct. 13, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
October 12, 2021 * 8 posts * 102 views
J_lope82 said: Thanks I'll try it. Is the notch on the drive shaft side? I have to match it up to a mark on the differential side is that correct? Read more >>
October 13, 2021 * 3 posts * 18 views
delling3 said: Been talking to Madd Retros about a set of their headlight retrofits. I am leaning towards LED's. The price is a bit painful if I am being honest. I also have some hesitancy because ... Read more >>
October 12, 2021 * 9 posts * 92 views
Blueraz_5.0 said: Its probably a combination of the dust that gets blown up here and some fade. Cant quite tell, but there isn't much sunfade on the paint, and the original owner garage kept it. Read more >>
October 12, 2021 * 4 posts * 44 views
Tazzy said: Actually when I use the screw driver to pull the drivers door pull it was cracked but not broken so when I painted it I let it dry good and I guess the extra bit if thickness from ... Read more >>
October 12, 2021 * 3 posts * 22 views
Duff said: I just bought this car and went to do some brake work on it, and noticed it has the steel lug nuts with the separate stainless cap, I'd like to upgrade to a 1 piece chrome nut. ... Read more >>
October 12, 2021 * 5 posts * 69 views
joemomma said: Yeah, seems like it not common at all. I finally found some pictures that show it removed, looks much better. Read more >>
October 12, 2021 * 2 posts * 31 views
96blak54 said: Thats gotta suck! All that fun replacing stock parts with upgrades and something totally different stops working.....this sounds exactly like my luck!!! I know nothing about convertibles ... Read more >>
October 12, 2021 * 21 posts * 198 views
Blueraz_5.0 said: I'm pretty small so I keep wanting to turn em into a little couch, make a wooden frame to cover the exposed foam and just have a mini couch. Read more >>
October 12, 2021 * 1 post * 8 views
SN95Newsletter said: Click here to view on the web Highlighted posts Life expectancy of a 94 gt clutch slave cylinder? October 11, 2021 * 5 posts * 50 views 94-95 5.0 - Specific High frequency vibration ... Read more >>
Continue reading...
RevBott
